Table saw blades (sawstop, if it matters)
Forum topic by Elizabeth posted 10-02-2013 11:19 PM 4442 views 0 times favorited 27 replies Add to Favorites Watch
View Elizabeth's profile
Elizabeth
817 posts in 3172 days
10-02-2013 11:19 PM
I want to take better care of my tablesaw blades. Until now I was actually using the stock one that came with my sawstop but I managed to trash it on plywood and laminate, so I have switched to a Freud blade that I bought at the same time as the saw. Lovely, cuts like butter.
But it’s still my only blade. I imagine I should branch out a bit more and have different blades for plywood, ripping, etc? What do I need? And are there any 10” blades that are not compatible with Sawstop and should be avoided?
I did pick up one of these at Harbor freight recently, since I was there. I figured if I can’t use it in the table saw for some reason I can put it in the miter saw (which is also still the stock blade!)
27 replies so far
View cdbetterley's profile
cdbetterley
6 posts in 1732 days
#1 posted 10-02-2013 11:41 PM
I’ve been haunting ebay looking at blades, got a very good deal on a new Forrest WWII blade! Now looking for a dado set there.
-- In the search for knowledge there are no stupid questions, just stupid answers!
View Ottacat's profile
Ottacat
480 posts in 1880 days
#2 posted 10-02-2013 11:46 PM
I have a Forrest WWII blade that I use for most of my work including modest amounts of plywood. I also have a Freud rip blade that I use when ripping 8/4 stock. The rip blade cuts easier and with less burning, especially in cherry and hard maple.
View AandCstyle's profile
AandCstyle
3075 posts in 2286 days
#3 posted 10-02-2013 11:49 PM
Elizabeth, be careful about using a TS blade in a MS. I seem to recall that there is a different blade hook angle or something like that which makes it kind of dangerous. Hopefully, some knowledgeable person will be able to shed some light on this issue. My memory isn’t what it once was, so I could be totally mistaken and it is fine, but better safe than sorry.
-- Art
View CharlesA's profile
CharlesA
3330 posts in 1826 days
#4 posted 10-02-2013 11:53 PM
Not sure how many folks will agree with me, but I think a nice blade on a well-adjusted, but not high end table saw will give better results than a $12 HF blade on a SawStop. There are a lot of really nice, more expensive blades out there, but I use these two which work well for me:
Rip:
Crosscut:
Elizabeth
#5 posted 10-03-2013 12:00 AM
Art, exactly why I am asking :) The HF one is still in its package.
View cutworm's profile
cutworm
1075 posts in 2822 days
#6 posted 10-03-2013 12:05 AM
Save the HF blade for cutting used lumber, etc. The only blade I use is a 50t combo from CMT. Does a nice job.
I second not using it in your miter saw.
-- Steve - "Never Give Up"
View unbob's profile
unbob
810 posts in 1932 days
#7 posted 10-03-2013 12:40 AM
I am cutting a lot of wood these days,
Most of the time, the Freud general purpose blades have worked better “FOR ME” then the Freud combination type. I get some burning from the combination style on maple for example, but they do work pretty good.
The GP blades are rated for an inch or so on rip cuts, but does 1 1/2” just fine, with no burn.
I mostly use 12”blades on a larger saw but the 10” 40 tooth GP blade does a good job on my 1 1/2hp contractors saw.
If I am doing deep rips, I use proper blades for it.
View GT350's profile
GT350
368 posts in 2010 days
#8 posted 10-03-2013 01:08 AM
My blades consist of just one combination blade and one dado blade. I had a very good combination blade for more than 15 years but one of the companies that I had sharpen it, sharpened it incorrectly and it was never the same after that. When I bought my Sawstop I tried the blade that came with it and still liked my old one better, it was quieter and cut better. Anyway, I bought a new Forrest WWII and I haven’t used it much but I tested it on some 4/4 maple, cherry and oak and also some 8/4 oak. This blade cuts like butter and very smooth. The only extra blade I may buy is a good plywood blade because especially with oak plywood across the grain you can get chipout. I talked to Support at Sawstop and they suggested I didn’t get the thin kerf blade because there are some that will fold if the brake fires. My saw is the 1 3/4 hp and with the standard kerf I didn’t see any lack of hp. Keep in mind that if you are changing blades frequently you will also have to adjust the brake if the blades are not very close to the same diameter.
Mike
View knotscott's profile
knotscott
8057 posts in 3404 days
#9 posted 10-03-2013 01:11 AM
I’d take the HF blade back…it’s no better than a stock blade, it won’t stay sharp long, and the hook angle is too steep for a miter saw. For another $10 or so, you can get a fairly nice blade that’s perform well and stay sharp longer.
The ABC's of Picking Saw Blades
Saw Blade Bargains
View Woodendeavor's profile
Woodendeavor
276 posts in 2635 days
#10 posted 10-03-2013 03:55 AM
I did allot of work with blades I could get at the big box store…mostly freud. I wanted to step up my game as a wood worker and started researching blades. I went with a Tenryu Gold Medal and I dont think I will buy another blade. Tenryu has a patent on side grinding their blades that drives the other manufacturers crazy but to maintain that blade you have to send it out to get sharpened
View Woodknack's profile
Woodknack
11826 posts in 2409 days
#11 posted 10-03-2013 08:02 AM
Get a good rip blade. The best thing you can do for your blades is keep them clean, various products for that.
View NiteWalker's profile
NiteWalker
2737 posts in 2605 days
#12 posted 10-03-2013 10:12 AM
The only blades I use in my saw, aside from a 24 tooth rip blade for flat bottomed grooves and for box splines.
I never drank the wwII kool-aid; my $18 blades have been serving me well since I started woodworking 8+years back.
View bigblockyeti's profile (online now)
bigblockyeti
5140 posts in 1749 days
#13 posted 10-03-2013 12:16 PM
I have several old delta blades, mostly combination, that I got when the mill shop I worked in shut down. If I remember correctly, these were selling for around $115 each back in the day. The kerf is pretty substantial, but it has to be as the plate is fairly thick. They cut great whether sharp or dull, just require lower feed speeds and more hp. The carbide is very thick and one of them I have had sharpened several times and it still has at least half it’s life remaining.
View mnguy's profile
mnguy
193 posts in 3427 days
#14 posted 10-03-2013 01:17 PM
A second on adding a rip blade to your GP or combination blade. I have the Freud glue line rip, and it is awesome for ripping stock, and truly leaves a glue ready edge.
View Manitario's profile
Manitario
2630 posts in 2911 days
#15 posted 10-03-2013 01:34 PM
I have 2 “go to” blades for my TS; a Freud p410 as my mutipurpose blade and a Freud thin kerf ripping blade that I’ll use if I’m cutting some monster thick slabs. Cheap blades generally equal rougher cutting….
