| Forum topic by Hrolfr | posted 370 days ago | 354 views | 0 times favorited | 17 replies | ![]() |
370 days ago |
This past weekend my wife gave me an early Christmas gift. She took me to woodcraft and bought me a new Jet 10in Proshop Table saw. I have listed the saws specs: Exclusive 30” ProShop fence system with T-square design Integrated arbor lock allows for quick, safe and easy blade changes Heavy-duty cast iron table with T-style miter slot provides large flat work surface and increased cross cut capacity Enclosed cabinet with exclusive leg stand design for easy assembly 4” dust port for increased dust collection efficiency Rigid, left tilting cast iron trunnion Powder coated paint for a long-lasting, chip-resistant finish Steel extension wings for added workpiece support Arbor Diameter: 5/8” Arbor Speed: 3600 RPM Blade Diameter: 10” Dust Collection Minimum CFM Required: 350 Dust Port Diameter : 4” OD Maximum Cross Cut: 21” Maximum Depth of Cut: 3-1/8” Maximum Depth of Cut at 45 Degrees: 2-1/8” Maximum Diameter of Dado: 8” Maximum Rip Left of Blade: 12” Maximum Rip Right of Blade: 30” Maximum Width of Dado: 13/16” Miter Gauge Type: Deluxe Motor: 1-3/4 HP, 1 PH, 17/9 Amps, 115/230V Prewired 115V Overall Dimensions: 39” H x 35” W x 60” L Table Height (in.) 34-3/4 Table in Front of Saw Blade at Maximum Depth of Cut (in.) 10-1/2 Table Size with Standard Extension (L x W/in.) 27×44 Table Size without Extension (L x W/in.) 27×20 Table Size without Wings (L x W/in.) 27×20 So the question is should I use a thin kerf or full kerf blade with this saw??? Also what is everyones favorite blade??? -- Hrolfr |
