Looking for 3-d cnc
Forum topic by Arthouse posted 10-01-2013 02:04 AM 1753 views 0 times favorited 27 replies Add to Favorites Watch
View Arthouse's profile
Arthouse
250 posts in 2890 days
10-01-2013 02:04 AM
I am looking for someone who can cut out human faces or heads out of wood for a project. Please let me know if anyone is interested in cutting out several heads who has done this before.
-- "The hand is the cutting edge of the mind but the wind and sun are the healing factors of the heart
27 replies so far
View mahdee's profile
mahdee
4045 posts in 2007 days
#1 posted 10-02-2013 12:20 PM
Hi, O.K. what do you mean? Human faces with eyes, ears, nose; i.e., carvings or face shapes cut out of plywood. What size? what kind of wood. What are they going to be used for, etc, etc, etc,
-- earthartandfoods.com
View DS's profile
DS
3045 posts in 2660 days
#2 posted 10-02-2013 04:56 PM
Well, just by way of information, to carve 3D objects with a CNC router, it takes more than the typical 3-axis CNC machine. Most people don’t realize that a majority of 3-axis machines can only process 2 1/2 D objects.
It’s this thing called interpolation. (Moving more than one axis at a time to form the desired geometry)
Think of an etch-a-sketch. To draw straight lines is simple. To draw a curved line, you need to “interpolate” the two directions, moving them the appropriate amount simultaneously to accurately create the curved line.
To do this in more than two simultaneous axis’ at a time requires a special controller and special (read expensive) software. Some “canned cycles” on some controllers can do limited 3D moves, but by in large it is un-necessary for most CNC work.
What you are looking for is someone with a 4-axis, or 5-axis machine with some advanced software.
This is far less common than the 3-axis fare used to make most cabinetry and furniture parts.
Hope this helps some.
View oldnovice's profile
oldnovice
7380 posts in 3607 days
#3 posted 10-02-2013 05:14 PM
This is a video of CNC that can do it a VERY expensive 5 axis CNC!
View Joe Lyddon's profile
Joe Lyddon
10374 posts in 4291 days
#4 posted 10-03-2013 01:11 AM
oldnovice
That is a beautiful CNC machine… Yep, a 3D CNC…
Should be able to make a Head or Bust on it… Sculpturing would be a piece of cake!
Now, we need to be able to develop the Program for the CNC machine to do it!
The development system is probably as much as the CNC machine!
You would really need to be able to run it through a Simulator to be sure it works rather than messing up so much wood, metal, etc. Just the Simulator would be a huge cost!
... in my imagination… One huge programming task…
Take a picture and convert it into the program required to carve it… Like a Head for a Bust….
I see nothing but $$$$$$$$$$$$ and TIME!
View Moron's profile
Moron
5032 posts in 4133 days
#5 posted 10-03-2013 01:16 AM
what DS said
unless you have a friend who owns a 4 axis CNC
your pissing in the wind
call a local community college, you might get lucky
View JAAune's profile
JAAune
1854 posts in 2556 days
#6 posted 10-03-2013 02:13 AM
Someone with minimal carving skills can use a 3-axis CNC to do human heads. Some software allows for indexed operations so a part can be rotated between machining operations. A little cleanup work would be needed at the top and bottom and that’s where the carving skills would be needed.
I plan to do a project like this myself within the next year and would be interested in this one too except I’m already over-loaded with work for the next few months.
View sras's profile
sras
4970 posts in 3368 days
#7 posted 10-03-2013 03:03 AM
I think these answers change if you focus on a face rather than an entire head. Your request presented either option – I’m pretty sure a relief of a face could be done on a 3-axis…
oldnovice
#8 posted 10-03-2013 04:34 AM
My son, a certified CNC machinist, did manage to make a 3D carving of a BMW 911 about 4” long on my Shopbot Buddy, not a 4 or 5 axis machine by any means!
I did not watch the entire process but he started cutting at the top then the two sides …. etc! For an experiment it turned out pretty good. I guess he was the “indexer” in this case!
View DS's profile
DS
#9 posted 10-03-2013 02:51 PM
There is a technique called “rastering” where a small bit is stepped in very small increments from one end to another and the profile is cut a line at a time.
This is still 2 1/2 D as the one axis doesn’t move while the other two do. This creates a bit of a rougher cut that has to be touched up, but it isn’t entirely unfeasible.
Joe Lyddon
#10 posted 10-06-2013 06:33 PM
oldnovice
That sounds like an interesting unique way of accomplishing the unusual.
I was thinking…(really!)... Google and their SKETCHUP… if they could interface that software to a CNC interface(able to handle the axises problem), that might save a TON of money in development!
JAAune
#11 posted 10-06-2013 06:55 PM
Sketchup does indirectly interface with CNC. I’m modeling objects in that software then exporting stl and dxf files for importing into my CAM software.
oldnovice
#12 posted 10-07-2013 04:17 PM
JAAune what do use use for your modeling for CNC? I use Creo Elements Direct as it creates 2D PDF prints that I can use with my CNC.
View PineChopper's profile
PineChopper
188 posts in 2436 days
#13 posted 10-07-2013 04:39 PM
https://store.carvewright.com/offers.php?mode=offer&offerid=65
Carve Wright has what seems to be an awesome machine. My friend told me about it. He’s made some really nice molding. If my business ever expands in that direction, I’ll consider one too.
carvewright.com or the above website is this months special.
Hope this helps you.
View Ripthorn's profile
Ripthorn
1459 posts in 3224 days
#14 posted 10-07-2013 04:51 PM
I’ve got a little 4 axis CNC mill, but haven’t actually used the 4th axis yet. But in order to really do what you are wanting, either indexed (probably 12 positions for best result) or a 4th axis are needed. The machine isn’t really the problem, it’s getting the CAM program to accurately produce the G code necessary to do all the operations. I have been learning that there is a lot more to running a CNC than drawing a part in CAD. The CAM process requires quite a bit of knowledge and foresight in order to get a program out that will actually produce the result you want.
For anyone interested, the LinuxCNC package is free and works pretty well, mine is running in 4 axis mode, though I just don’t use the A axis currently.
View DS's profile
DS
#15 posted 10-07-2013 06:15 PM
I was impressed with the Carvewright software utilities and many of the features. (e.g. Digitizing probe)
Where the Carvewright loses me is that it seems to be a lightweight hobby machine that might not hold up under continuous production runs. It more resembles an Inkjet Plotter than a CNC machine.
I wish I had some of those features on a larger, more industrial machine.
