Simple Box Joint Jig
Forum topic by MrRon posted 09-30-2013 11:07 PM 1468 views 0 times favorited 1 reply Add to Favorites Watch
View MrRon's profile
MrRon
5086 posts in 3391 days
09-30-2013 11:07 PM
Topic tags/keywords: jig
Here is a ¼” box joint jig that is a bit unconventional. To use:
1. Attach a piece of 2x material to the miter gauge.
2. When you know the width of the material you want to cut a box joint in,
3. Set the material, right side against the dado blade.
4. Set the stop block against the left side of the material
5. Start with a ¼” spacer to index the material to the wood the distance of ¼”
6. Make the cut.
7. Replace the ¼” spacer with a ¾” spacer and make the second cut.
8. Combine the ¾” spacer and the ½” spacer and make the third cut.
9. Continue until all the cuts have been made.
This method is a bit labor intensive, but it eliminates the need to get that first pin exactly right. I wouldn’t use this method if I had a lot of joints to make. For a one off project, it might be fun to use. This can also be used for 3/8” box joints, by changing the sizes of the spacer blocks.
1 reply so far
View bigblockyeti's profile
bigblockyeti
5229 posts in 1868 days
#1 posted 10-03-2013 12:49 PM
It’d be really slick if you could figure out a way to flip the spacers down into place, kinda like the stops on some fancy miter gauges. Having them in the right order would be the tough part.
