Rockwell Model 10 Band Saw?
Forum topic by tool_junkie posted 09-30-2013 08:03 PM 14991 views 0 times favorited 3 replies Add to Favorites Watch
View tool_junkie's profile
tool_junkie
326 posts in 2767 days
09-30-2013 08:03 PM
All,
I just came across a Rockwell Model 10 band saw on local craigslist. The seller is asking for $75 for this. It would be better than what I have right now, a Ryobi bench top model.
Any ideas/opinions on this saw? If I go to check it out, what should I be looking for?
Thanks!
3 replies so far
View mantwi's profile
mantwi
312 posts in 2134 days
#1 posted 09-30-2013 09:17 PM
The 10” saws are primarily for light hobbyist use. I have seen a video on the Rikon 10” that appears to be a cut above the rest but have never seen the model 10 Rockwell saw. You’ll want to look at the horse power, resaw capacity, blade guides, trunnion rigidity to make an informed decision about whether this saw will meet your needs. Even a small saw will resaw if you take your time and use a good blade so determine what you require. Bad blade guides can make it impossible to track a saw properly and a flimsy, flexing trunnion is the kiss of death when you want the angle you set the saw at to be the angle it cuts. Check out this video to establish a benchmark to shoot for. I know this saw is probably not in your budget for now but it demonstrates what a good 10” saw should be but at the price you could find a good used 14” model
http://www.youtube.com/watch?v=M9630dj_9jk
View rustfever's profile
rustfever
762 posts in 3548 days
#2 posted 09-30-2013 09:32 PM
I purchased a used Delta-Homecraft #10 band saw in 1972. It served me faithfully for 40 years.
However, my needs outgrew this versatile little machine, [or so I thought]. I now have a 18” Laguna, 14” Delta and a 36” Yates/American. I was using the 10” machine very infrequently, except for very tight work.
I was talked out of the machine about a year ago. I now miss it and wish I had it back.
IT WAS BULLET PROOF! I had it dialed in and adjusted to work very well. Kept adjustments and work nice.
Now, I have an eye out for another, just like it. Oh, and it only had 1/2 HP motor, but it never bogged down.
IMO, you sure could find a number of machines that would never ‘hold a candle’ to this great tool.
-- Rustfever, Central California
View Blackie_'s profile
Blackie_
4883 posts in 2751 days
#3 posted 09-30-2013 10:09 PM
That Rockwell is the same if not worse then you have now, Rockwell aren’t what they used to be, they are now a cheap knock off, I’d even go as far as to put Ryobi above them, don’t waste your money.
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
