Butcher Block Countertop, couple questions
Forum topic by aawshads posted 09-30-2013 07:38 PM 1460 views 0 times favorited 9 replies Add to Favorites Watch
View aawshads's profile
aawshads
7 posts in 1675 days
09-30-2013 07:38 PM
Topic tags/keywords: counter top advice walnut joining maple
Ok, in the process of building a butcher block counter top for my island in the kitchen. It is strips of Walnut and Rock maple. Finished it will be 72” x 36” x 2”. That makes it extremely heavy. I was thinking of making it 2 parts and joining them with draw bolts. This is not an end grain top, each wood strip is 36” long, glued up into panels. I surmise that this will do 2 things, 1) make it easier to manage and install, 2) help ease some of the stresses in the wood when environmental changes happen. In order to further ease those stresses I also plan to make it a floating counter top, securing it using screws fastened through a larger hole/washer combo to give it a little room to move if necessary.
Next thing, this will not be a counter we plan on cutting on, more for aesthetics. What would you finish it with? I for sure want the wet look, have thought about the old standby of mineral oil, but I do not know if reapplying monthly will be too much of a pain or not. That is more than likely what I will do if no one has a better suggestion. thanks all
9 replies so far
View MrRon's profile
MrRon
4710 posts in 3207 days
#1 posted 09-30-2013 07:59 PM
Use a polyurethane varnish on all surfaces and ends.
View chrisstef's profile
chrisstef
17302 posts in 2969 days
#2 posted 09-30-2013 08:04 PM
Im working on a similar project, walnut counter tops. Ill be using General Finishes Arm-A-Seal on a suggestion from Charles Neil. My other choice would have been Waterlox Orignal Formula.
aawshads
#3 posted 09-30-2013 08:14 PM
Thank you both. That Arm R Seal looks interesting, i will inquire into it further…
chrisstef
#4 posted 09-30-2013 08:33 PM
Ive used it on a small ambrosia maple coffee table I made about a year and a half ago. Just last night I watched my one year old son beat on that soft maple top with one of his toys relentlessly. Not a scuff to be found in the finish.
Good luck on the build aawshads.
View BHolcombe's profile
BHolcombe
180 posts in 2039 days
#5 posted 09-30-2013 08:36 PM
My choice would be a food-safe oil. Aesthetic or otherwise this is a countertop.
View Charlie's profile
Charlie
1100 posts in 2249 days
#6 posted 09-30-2013 08:37 PM
Waterlox
‘nuff said.
chrisstef
#7 posted 09-30-2013 08:41 PM
That was the reasoning for my other finishing choice being Waterlox ^
Im shying away just from my lack of usage with it. Besides that, Charlie’s post has a great write up on how he achieved such a great finish. Ill be following the same application process just using a different product.
aawshads
#8 posted 10-01-2013 02:07 AM
where is the article? i have looked at his blog and projects, i would love to read it.
also any comments on two pieces vs one?
chrisstef
#9 posted 10-01-2013 03:57 PM
http://50.115.35.242/topics/44962
It toward the bottom of this thread.
