drum sander motor issue
Forum topic by Betsy posted 09-30-2013 03:06 AM 1575 views 0 times favorited 26 replies Add to Favorites Watch
View Betsy's profile
Betsy
3391 posts in 3896 days
09-30-2013 03:06 AM
Topic tags/keywords: drum sander motor
Slowly but surely spending more time in the shop. Have even done a couple of small shows with lots of help from friends …. but still making sawdust.
I have a Delta 36” drum sander that has always been a good steady tool. However, tonight it simply quit. The table belt moves but the drum does not. It worked for about 3 passes then just stopped. The red reset button on the motor is popped but it will not reset. I’m not mechanically gifted so if someone could give me some idea of what might be wrong I’d appreciate the help. The sander is about 13-14 year’s old.
Thanks in advance.
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
26 replies so far
View lew's profile
lew
12062 posts in 3756 days
#1 posted 09-30-2013 03:28 AM
Betsy-
Some of the reset buttons are “thermal activated”. Maybe when the motor cools down it might reset.
View ZacD's profile
ZacD
34 posts in 1759 days
#2 posted 09-30-2013 03:38 AM
That sounds likely to me as well lew. What is your wiring like in your shop / house? Were you running other major appliances on other circuits?
View MarkwithaK's profile
MarkwithaK
370 posts in 3178 days
#3 posted 09-30-2013 03:43 AM
The thermal overload will trip when the motor gets hot typically due to overamping. Unplug and let it cool down then try to reset.
-- If at first you don't succeed then maybe skydiving isn't for you.
View Monte Pittman's profile
Monte Pittman
29233 posts in 2338 days
#4 posted 09-30-2013 03:44 AM
The thermal idea is possible. Also, it may have reset. But if you have GFI outlets in your shop, it may have tripped it aswwell. Worth a look.
Betsy
#5 posted 09-30-2013 04:12 AM
My dust collector and drum sander are on the same circuit with no prior problems. I did, however switched the sander to a different circuit. With no change. I’ve never heard of a thermal switch but makes sense. I’ll try again tomorrow and see what happens. If the red reset button does not reset, or the sander simply does not start what would be my next step…
Also why would the table belt run but not the drum? Could it simply not be getting enough power through the motor to run both? (I know I am now showing my lack of understanding about how motors work. I really should have paid more attention to my dad’s conversations at the dinner table growing up.) thanks for the help.
View tefinn's profile
tefinn
1222 posts in 2437 days
#6 posted 09-30-2013 05:12 AM
Betsy – You actually have two separate motors in your sander. One drives the belt and one the drum. The larger one in the bottom is for the drum. If you have any cooling vents on the motor, blow the motor out with your air compressor to remove any dust. The dust could be causing the motor to overheat and trip the thermal switch.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
View ZacD's profile
ZacD
#7 posted 09-30-2013 05:13 AM
The next step depends on how mechanically inclined you are or are how much you are willing to learn or tinker. Personally, I’d tear into the thing and have a look around. I’m not sure how the radial motion is achieved in those units. Being 15 years old could mean there is some grease that is starting to get very tacky and getting really cakey with the saw dust, gumming up axels or chains or whatever else may be moving in there.
Also, I misunderstood your issue earlier. Is the table belt moving when you turn the unit or or is it just able to freely move when you push against it? Are there any strange new buzzing sounds when you turn the unit on or does it sound quieter? Be extra careful not to leave the unit on for more than a few seconds if you do hear buzzing.
Otherwise, if the unit doesn’t turn on at all (how I previously understood), it seems more like a motor issue, rather than a drive train issue (belts. chains, gears) but it could be both in the end. You could have an overheated motor which could be from low available current (if you had other appliances on) or from over high current draw if something was ceasing up the drive train.
There are still other possibilities but these are the likeliest that come to my mind.
Edit: Also, did the table belt typically freely move and did the drum freely move prior to this? Did they both move if you moved one? Its a good possibility that the drive trains are completely separate. So it is possible that the mechanics of the drum have ceased up or it could be that the drum used some special gears that would inhibit motion by pushing on the drum.
View Blackie_'s profile
Blackie_
4883 posts in 2513 days
#8 posted 09-30-2013 04:06 PM
Is it possible that bad brushes could cause the problem she is having? I just had to replace mine on my planer.
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
View ZacD's profile
ZacD
#9 posted 09-30-2013 04:49 PM
The sander uses a capacitor start, continuous run, ac induction motor. These are the quiet motors you find on your larger table saws et al. so brushes shouldn’t be an issue here. But that did make me think of one other possibility.
We have a 10” Craftsman hybrid marble top table saw at work that had an issue with its motor about 6 months ago. Investigating the matter we found that a capacitor had at some point literally caught fire and had charred the inside of its cage and a bit of the connecting wires. Quite scary to see that after the fact; of course, Craftsman were like, ‘yeah and so what, what are we supposed to do about it’ but that’s a different matter.
Anyway, definitely check the capacitor cage on the motor. If the capacitor popped or caught fire, it would have definitely caused your machine to stall out with the reset button being extended out.
View bigblockyeti's profile
bigblockyeti
5121 posts in 1721 days
#10 posted 09-30-2013 05:08 PM
When trying to reset the overload button on the motor, usually they can be pushed in and will not “catch” until the motor cools down, usually over five minutes, very rarely over 30 minutes. If the button won’t stay down, the overload switch is toast. They can be changed out, but are sometimes difficult to find a replacement, especially on a foreign made motor. A motor shop could do it for you, but after parts and labor you’d be close to the price of a new foreign made replacement or lightly used domestically manufactured motor. Checking the capacitor is a good idea too, if there is any open circuit anywhere it’s going to cause problems with either running or starting, if not both.
Betsy
#11 posted 09-30-2013 05:10 PM
thanks for the help guys.
Zac the table moves on it’s own – no hand power required. I also do not hear any noise at all when I turn on the machine – just my mumbling when it does not work. :-)
I am not sure where brushes are in the motor – .
I’m pretty much not mechanical – but if it comes down to having to change the motor out – I should be able to do that as I managed it on my bandsaw several years back.
I have no idea what a capacitor cage should look lilke, but I’ll check my manual.
my plan of action for when I get home from work is:
Double check that I’m not on the same circuit as my dust collector
Use some compressed air to blow out the vents
Check my manual for the capacitor location (and hopefully it has a nice picture for me)
Push in the red reset button
Turn it own and cross my fingers.
Thanks again for the help. I’ll let you know how I do.
Betsy
#12 posted 09-30-2013 11:17 PM
Well – got a great big nothing to report on progress. Could this be a switch issue and not the motor? How can you check if a switch is based?
Thanks all
View JustJoe's profile
JustJoe
1554 posts in 2038 days
#13 posted 09-30-2013 11:21 PM
You can check the switch by bypassing it. Take the cover off the motor and wire a cord/plug directly to it, and plug it in the wall. If the motor runs, it’s the switch. If it doesn’t, it’s the motor.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
tefinn
#14 posted 09-30-2013 11:39 PM
Betsy – Is the belt still turning when you turn it on? If it is, it’s not the main switch. As i said in my last reply, you have two separate motors in the sander. One for the belt and one for the drum. Did the reset stay in when you pushed it in? If it didn’t, then it’s a good chance the reset is bad. If it did, and tripped again, then you may have a bad capacitor or other internal motor problems.
View lew's profile
lew
#15 posted 09-30-2013 11:54 PM
Betsy,
A bad capacitor usually causes the motor to “hum” but not start.
(I think the capacitor stores the words and when it goes bad the motor just hums the tune. I know I’m a smart ass).
Be very careful when taking stuff apart. Make some simple drawings of where the wires go and the wire colors. Make sure it is unplugged too!
You mentioned you swapped out a band saw motor. You could check the switch by pulling the wire cover on the sander motor, unhooking the black and white wire (or what ever colors go the terminals in the motor) and then connect a 120v lamp to the wires. Turn the unit on. If the light comes on, the switch is good and the problem is in the motor. No light and the problem is in the switch.
