I had a vital piece of equipment die today.
Forum topic by bullhead1 posted 09-30-2013 03:06 AM 1347 views 0 times favorited 22 replies Add to Favorites Watch
View bullhead1's profile
bullhead1
228 posts in 2121 days
09-30-2013 03:06 AM
Where do I start? I’m a long time Minnesota Twins fan and this season has been painful. The end of the season was so hard today as I watched the final game of the season and doing some design work on my computer.
I took out my frustration of their loss by resawing some wood for a an upcoming project. That didn’t work so I went to my old trusty machine to sooth my pain.
When I approached her I noticed something not quite right. There was a puddle of water under the front of the doors. She has been so reliable for a lot of years and has always done what I asked. Always performed to perfection especially when it was hot out. But today I think I lost my beloved helper. I slowly opened her up and felt the vessel that would maybe sooth my sorrow of the day. My eye’s watered as my hand touched a semi-cold can of Miller Lite. Not the ice cold one that she usually provided.
She has done so much work for me, from holding my to do lists with magnets to the small girly calendar from the local auto parts store. Held my meat and cheese snacks and yes a case of water and soda.
Today, I lost my beloved shop refrigerator. I think she is too far gone to refurbish her practically. Now I must decide how to give her a proper burial. But more important I need help from you LJ’s. I hate to start another one of these threads, but….....
What refrigerator do you recommend and should I buy new or look on craig’s list?
This is such an essential piece of equipment of any shop/man cave. I think it is important to do as much research as possible. I’m sitting here having a lukewarm beer in her honor pondering what to do.
22 replies so far
View Monte Pittman's profile (online now)
Monte Pittman
27684 posts in 2210 days
#1 posted 09-30-2013 03:24 AM
It’s somewhat odd how we gain respect for some of our machines. When my planer died a couple months ago, I almost felt like it needed a funeral.
I recommend buying new. Start fresh.
-- Mother Nature created it, I just assemble it.
Monte Pittman
#2 posted 09-30-2013 03:25 AM
Look at the bright side of baseball, the Yankees are sitting at home also.
View MarkwithaK's profile
MarkwithaK
370 posts in 3050 days
#3 posted 09-30-2013 03:40 AM
Before you go off and dig that hole, are you 100% certain that it’s dead? Being in a shop….especially a woodworking shop perhaps the coils are dirty. This would prevent the unit from cooling. Is the compressor running? Do you hear it try and start then and an audible ‘click’?
I’ve worked in refrigeration for nearly 10 years and you would be surprised at how many times it comes down to a simple fix to revive the departed so to speak.
-- If at first you don't succeed then maybe skydiving isn't for you.
MarkwithaK
#4 posted 09-30-2013 03:41 AM
And I feel your pain about this baseball season….I’m a die hard Cubs fan.
View Makarov's profile
Makarov
102 posts in 1677 days
#5 posted 09-30-2013 03:41 AM
I am a Mariners fan, I understand your pain. With the current short lifespan of fridges I would buy new.
-- "Complexity is easy; Simplicity is difficult." Georgy Shragin Designer of ppsh41 sub machine gun
bullhead1
#6 posted 09-30-2013 03:54 AM
Well, Mark I gave her CPR with the air compressor on the coils. I have not heard signs of life for several hours. She’s pretty old (20 years+) and unfortunately I am not real mechanical. I hate to pay a repair man 60 bucks and find out it’s terminal. Could it be the defrost timer? If it’s the compressor, I would think that would be like a heart transplant.
Monte Pittman
#7 posted 09-30-2013 03:59 AM
Defrost timer is actually a common failure and usually easy to replace.
MarkwithaK
#8 posted 09-30-2013 04:04 AM
Defrost timer, thermostat, start components. Generally speaking a compressor is a pretty stout component and can last a good long while (especially the older ones) and given the longevity of newer units (I still say that they are designed with a certain life span) it may be worthwhile to repair it.
MarkwithaK
#9 posted 09-30-2013 04:05 AM
If it is stuck in defrost that will keep the compressor from cycling. You should see a ‘slot’ on the timer to advance it which should close the contacts for the compressor.
bullhead1
#10 posted 09-30-2013 04:15 AM
Ok Mark I’m ignorant. Where is the timer?
View jonah's profile
jonah
1517 posts in 3170 days
#11 posted 09-30-2013 01:22 PM
A new, efficient fridge will pay for itself in energy savings in no time. Old fridges are the worst culprits – they are horrendously energy-inefficient.
View bowedcurly's profile
bowedcurly
519 posts in 1601 days
#12 posted 09-30-2013 03:29 PM
it’s about winter time you really don’t need a fridgitator
-- Staining killed the wood<<<<<>>>>>Dyeing gave it life
MarkwithaK
#13 posted 09-30-2013 04:06 PM
Typically they are located on the lower rear of the chassis. Small plastic box with several wires leading to it.
Smitty_Cabinetshop
14954 posts in 2490 days
#14 posted 09-30-2013 04:29 PM
I don’t feel the pain of baseball being over (Cardinals fan) and my shop fridge runs fine. But I do appreciate the post and the impact is serious. Hope you get her running soon!
View bigblockyeti's profile
bigblockyeti
4881 posts in 1592 days
#15 posted 09-30-2013 04:36 PM
For a shop fridge, definitely shop Craigslist. You can get what you need for a fraction of what it would cost new and last nearly as long, given the shop environment will probably be the killer verses old age.
