DW735 Planer chain tension spring?
Forum topic by Mark828 posted 09-28-2013 11:53 PM 1952 views 0 times favorited 9 replies Add to Favorites Watch
View Mark828's profile
Mark828
95 posts in 2011 days
09-28-2013 11:53 PM
Topic tags/keywords: planer question
I was cleaning up my planer today and when I took the cover off the side with the height adjustment handle to reveal a feeder chain and belt I noticed there was a spring broken that looks like it was meant to activate a little wheeled lever that put tension on the chain
I’m not real sure how long it’s been broken but I’ve been using it a lot lately and haven’t noticed anything about it running odd. I plan on fining a replacement spring tomorrow but am wondering if it is a bad thing that it’s been ran a lot with it broken or was it just meant to keep the chain from popping loose.
Help…!
9 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3795 days
#1 posted 09-29-2013 12:00 AM
Might be an idler spring. Having the drive chain flap around may cause undue wear and tear and it may leave the chain in a position to flip off. I think you are on the right track planning on fixing it. You may get by fir the rest if tge life if the planer or the next board through could flip the chain off and bust a chain or gear tooth.
View DKV's profile
DKV
3940 posts in 2587 days
#2 posted 09-29-2013 12:36 AM
Mark, can you post a picture?
Thanks,
-- This is a Troll Free zone.
Mark828
#3 posted 09-29-2013 12:46 AM
Here.
View ajosephg's profile
ajosephg
1880 posts in 3644 days
#4 posted 09-29-2013 12:54 AM
Yep – it’s a chain tensioner. Fix it ASAP.
-- Joe
Mark828
#5 posted 09-29-2013 12:56 AM
Will do!
View JoeinGa's profile
JoeinGa
7739 posts in 2090 days
#6 posted 09-29-2013 12:58 AM
Yup. it’s the chain tensioner. And while you’re at it, put a few drops of oil on that chain too.
Mark Shymanski
#7 posted 09-29-2013 01:59 AM
Would graphite spray work here? I always wonder if the oil doesn’t pick up sawdust and cause clogging. I’m not sure if the graphite spray would provide enough lubrication though.
View tefinn's profile
tefinn
1222 posts in 2520 days
#8 posted 09-29-2013 03:05 AM
Dewalt recommends lithium grease spray on all the chain drives of their planers. I was told this by the Dewalt service rep that serviced my store for tool demos and RTVs when I worked for HD.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
Mark Shymanski
#9 posted 09-29-2013 03:08 AM
Lithium grease makes sense.
