Respirator for spraying Sherwin Williams CAB acrylic lacquer?
Forum topic by mbs posted 09-28-2013 05:36 AM 2041 views 0 times favorited 8 replies Add to Favorites Watch
View mbs's profile
mbs
1652 posts in 2933 days
09-28-2013 05:36 AM
I’m looking for a specific recommendation for a half mask respirator that will protect me while spraying T75 lacquer. I’ve done some research but the suggestions are generic like – read the msds and use an appropriate respirator. And when I read the respirator jargon it’s generic too. There are many options and none of them say “use xyz”.
I need something that protects against Naptha, Ethylbenzene, Xylene, Ethanol, 2-Methyl-1-propanol, Methyl Ethyl Ketone, MAK, Isobutyl Acetate, Amyl Acetate.
Do you have a specific recommendation?
Thanks,
-- Sorry the reply is so long. I didn't have time to write a short reply.
8 replies so far
View NiteWalker's profile
NiteWalker
2737 posts in 2570 days
#1 posted 09-28-2013 11:21 AM
3m 7500 series mask and organic vapor cartridge filters.
Works great.
View Clint Searl's profile
Clint Searl
1533 posts in 2354 days
#2 posted 09-28-2013 11:50 AM
S-W CAB is a great finish. You’ll like it. The Medium Rubbed Effect sheen is just right.
View tefinn's profile
tefinn
1222 posts in 2430 days
#3 posted 09-28-2013 02:43 PM
+1 on the organic vapor cartridges. I use a North 7700, but the 3M 7500 is very good also.
I use this chart from 3M to pick which filters to go with what chemicals are being used.
http://multimedia.3m.com/mws/mediawebserver?mwsId=SSSSSu7zK1fslxtUOxmG4x_Sev7qe17zHvTSevTSeSSSSSS--
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
4980 posts in 2486 days
#4 posted 09-28-2013 02:48 PM
I use both the 3M masks and the North models, but more important than the brand is the way the mask fits you. Getting the proper fit was a verified process when I had a day job, but a good quick check is with it on cover the inlet and inhale. It should seal very well around your face (if you have facial hair you’re SOL). Also, cover the outlets and blow. You can usually feel the seal with these tests. Aside from that, get some carbon (organic vapor) filters to fit the particular model and you’re set to go. The carbon in those filters is constantly trying to absorb organic vapors, so when not in use be sure to keep them in some kind of air tight container. If all else fails zip lock bags will work, but something more robust would be better. You might as well pick up some dust cartridges for it as well, then you can use it for sanding or whatever else you may need.
tefinn
#5 posted 09-28-2013 03:03 PM
That’s very true Fred. I have a small face and have to wear small to medium sized masks. Large sizes leak too much. Also, the catridges should be changed after at least every 8 hrs of use, sooner if in a high concentration use.
View mbs's profile
mbs
#6 posted 09-28-2013 04:48 PM
Thanks for the comments. based on all the information provided I settled on the 7503 mask, 6001 organic cartridge and P95 filter.
View Grandpa's profile
Grandpa
3259 posts in 2668 days
#7 posted 09-28-2013 07:15 PM
Good investment. I use 3M respirators. I buy mine from McFeely’s. That is the fastener place. They ship for a dollar. These are inexpensive even discounting the doctor’s call if you don’t use one. I don’t feel that may of these seal perfectly so I use petroleum jelly around the part of my face where the mask seals. This does the trick.
View sgv's profile
sgv
266 posts in 1885 days
#8 posted 09-28-2013 08:56 PM
I work for SW great choice, use the cotton pre filter and change often. you can buy them in packs of ten, if you start to smell the lacquer you need to change them
-- Tite Lines, May the wind be at your back
