Grizz 0690
Forum topic by sgv posted 09-27-2013 11:50 AM 901 views 0 times favorited 4 replies Add to Favorites Watch
View sgv's profile
sgv
266 posts in 2127 days
09-27-2013 11:50 AM
Finally have my saw up and running, (Grizzly g0690 Pics coming soon) My question of the day ( I think I know the answer but just checking) i aligned the blade to the miter slot last night using a sliding square,I think i am very very close ( tooth just touches front of and back) I dont have a digital caliper, question 1 Is this close enough for safe and true cuts ? question 2 in the manual it said a lot of wood workers keep the fence a slight bit out of square, the tail end 1/16” so to reduce kick back I am out between 1/16 and 1/32 any thoughts?
as all ways thanks in advance LJs
-- Tite Lines, May the wind be at your back
View Bill White's profile
Bill White
5148 posts in 4195 days
#1 posted 09-27-2013 01:41 PM
I adjust to the saw plate, not the teeth. I’m not a big fan of the offset fence ‘cause, if I needed to cut from the right miter slot, the fence wouldn’t be square to the blade.
Doesn’t mean I’m right, just how I do it.
Bill
-- bill@magraphics.us
View toolie's profile
toolie
2148 posts in 2863 days
#2 posted 09-27-2013 04:56 PM
more than likely, yes.
both my saws’ fences are dead on accurate. that way, they can be safely used on either side of the blade should the need arise.
View PurpLev's profile
PurpLev
8548 posts in 3883 days
#3 posted 09-27-2013 05:08 PM
#1: yes, that is safe and good enough method to align blade to miter slot
#2: I keep my fence aligned with the miter slot (and blade). that way if I have to cut on the right side of the fence I dont induce any binding.
View sgv's profile
sgv
#4 posted 09-27-2013 11:10 PM
Thanks guys, did not think about cutting on the right side, tomorrow I will get it as close as I can.8)
