Fix butt joint that was pulled off center when screwing
« back to Joinery forum
Forum topic by ChuckH posted 09-26-2013 04:50 PM 948 views 0 times favorited 4 replies Add to Favorites Watch
View ChuckH's profile
ChuckH
70 posts in 2004 days
09-26-2013 04:50 PM
Topic tags/keywords: question help
I was building a… cabinet frame I guess, last night, using pocket holes. I made 8 joints perfectly. On the 9th I didn’t clamp good and the parts were not quite aligned when I drove the screws. The screws pulled a little, and now the part is proud a hair and also not quite straight. The frame is only 1.25”, so there is no room to drill new pocket holes.
I have removed one of the screws, which has let me rotate it slightly and get it back in line. It’s better but it could be perfect, and the joint is pretty weak now, although once I attach the top (.75” plywood) it should strengthen up. I’m wondering if there is another way to fix this though – fill the holes, with something maybe, and then re-do the screws?
Thanks,
Charles
View firefighterontheside's profile (online now)
19610 posts in 2094 days
#1 posted 09-26-2013 04:56 PM
Are you using glue? You could oversize the pocket hole a little by redrilling through it with a bit that is a little bigger than the screw threads. Now reclamp and drive screw again, thinking about gluing this one.
View pintodeluxe's profile
pintodeluxe
5816 posts in 3050 days
#2 posted 09-26-2013 04:56 PM
Sure, just glue Kreg wooden plugs in the pocket holes. Then fill the screw hole with a golf tee or sliver of wood.
Clamp it securely and try again. I recommend the Kreg brand clamps for holding the boards in place. It seems to work better than most.
Good luck.
View Lee Barker's profile
Lee Barker
2170 posts in 3088 days
#3 posted 09-26-2013 05:01 PM
I’d send a couple three short lengths of toothpick down the hatch with some glue, let it sit and then drive the screw again.
FYI, I prefer to glue things like this (even though it may have end grain involved), clamp and then, 30 minutes later, drive the screws. Parts won’t wander if you use this technique.
Kindly,
ChuckH
#4 posted 09-26-2013 05:37 PM
Thanks for all the tips! I’m going to try the glue-then-screw strategy next time I have a chance. In this case I ad the bright idea that I would assemble the frame, use a 3 wing cutter to do slots for the side panels, then disassemble and insert the frames. Bad idea – the frame parts are so small, I kept hitting the screws with the cutter. At least it was a cheapo HF bit, but it still stings to do something so dumb :)
