Planing Thick Maple?
Forum topic by jasoncarpentry posted 09-25-2013 06:41 PM 1098 views 0 times favorited 7 replies Add to Favorites Watch
View jasoncarpentry's profile
jasoncarpentry
142 posts in 2654 days
09-25-2013 06:41 PM
Topic tags/keywords: dw735 planning maple
I have a piece of maple 1.75” thick x 7’ wide x 38” long. It has a slight cup to it, but not much. My question is: Can I plane it directly using my DW735 planer? I know that, ideally, I need to shim up the board to take out all of the “rock” before planning the first side. But surely a board that stout won’t be forced down flat by the infeed / outfeed rollers!
Or will it? What’s been your experience?
-- Jim in Tennessee
7 replies so far
4986 posts in 2493 days
#1 posted 09-25-2013 08:08 PM
It won’t be forced down flat, but it will rock over to whatever point it balances when going through the planer. So it still won’t be flattened, but it will be smoothed up (mostly) on the planed side. It might also put a lot of pressure on the planer as it does that rocking.
404 - Not Found
2544 posts in 2969 days
#2 posted 09-25-2013 10:42 PM
Before you do anything, check for twist on the concave side with winding sticks. Correct any winding with a hand plane before putting it thru the planer.
View Tim's profile
Tim
3807 posts in 1961 days
#3 posted 09-26-2013 01:02 AM
No power planer here, just wondering. Won’t you have a good chance of planing twist (wind) into it if you don’t shim it? That’s what I see happening if you letter rip through without shims or doing renner’s method.
I guess it depends on what you mean by slight. What side were you planning on putting upwards?
View Wolfdaddy's profile
Wolfdaddy
300 posts in 1834 days
#4 posted 09-26-2013 04:17 AM
If there is any twist in the board it will still be there after planing.
-- "MOM! I think there's something under our house! I'm gonna need a jackhammer, a fish bowl, some air tanks, and maybe a few pipes."
jasoncarpentry
#5 posted 09-26-2013 11:40 AM
Everybody-
Thanks for the tips. Now that I’ve given it more thought, I’ve decided to use a sled and shim up the piece using wedges, secured in place with hot glue.
-- Jim in Tennessee
View ScrubPlane's profile
ScrubPlane
190 posts in 2196 days
#6 posted 09-28-2013 01:02 PM
Jim…The recommended method is to run the board across a jointer to create one ‘true’ flat side then run it through your planer to ‘true’ the opposite side.
View Bill White's profile
Bill White
4932 posts in 3960 days
#7 posted 09-28-2013 02:03 PM
Jim, the sled trick will certainly work. Just take light cuts.
Bill
-- bill@magraphics.us
