Brass gone green, whut?
« back to Hand Tools forum
Forum topic by Benvolio posted 09-25-2013 11:50 AM 1245 views 0 times favorited 4 replies Add to Favorites Watch
View Benvolio's profile
Benvolio
148 posts in 1893 days
09-25-2013 11:50 AM
I’ve been restoring an old Tyzack panel saw and went to polish up the old saw nuts
They cleaned up fine with a cocktail of white spirit and vinegar.
But the corrosion itself looked bluey/green and is that type of corrosion swells up space which makes me think its copper.
Any ideas, or is this normal for brass??
-- Ben, England.
View racerglen's profile
racerglen
3112 posts in 2742 days
#1 posted 09-25-2013 12:09 PM
Normal Ben, brass and copper both do it depending on the circumstance.
And by the color, you do have Brass nuts ;-)
-- Glen, B.C. Canada
View shipwright's profile
shipwright
7965 posts in 2760 days
#2 posted 09-25-2013 01:32 PM
Brass is mostly copper. Vinegar is an acid.
Acid + copper = copper oxide.
View Dark_Lightning's profile
Dark_Lightning
3141 posts in 3071 days
#3 posted 09-28-2013 11:43 PM
Vinegar is dilute acetic acid. You made copper acetate, which is the color you see. If you haven’t cleaned it all off already, you can use toilet bowl cleaner that has the organic acids in it (not chlorinated ones) to dissolve the corrosion. It’s what is used for “pickle” when cleaning scale from copper after heating. A teaspoon in a pint of water will do the trick. Just be sure to rinse well after cleaning. Then spray a little lacquer or some protectant on the brass, if you don’t like patina. BTW, brass is an alloy comprised of mostly copper and zinc.
-- Random Orbital Nailer
View Beorn's profile
Beorn
22 posts in 1668 days
#4 posted 10-02-2013 09:23 PM
Brass is an alloy of copper and zinc. You are right that the corrosion you are observing is from copper but that doesnt mean the saw nuts are not brass.
-- Try to learn something about everything and everything about something - Thomas Huxley
