Sealer under spar
Forum topic by Insagent posted 09-25-2013 01:41 AM 831 views 0 times favorited 4 replies Add to Favorites Watch
View Insagent's profile
Insagent
51 posts in 2305 days
09-25-2013 01:41 AM
Can I use a sander sealer under spar varnish? It’s on a walnut outdoor bench. Thanks
View tefinn's profile
tefinn
1222 posts in 2431 days
#1 posted 09-25-2013 02:21 AM
You can, but why? There is no reason to use sealer under spar varnish.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
Insagent
#2 posted 09-25-2013 02:27 AM
I was thinking it would pull the grain out more. Will it not?
tefinn
#3 posted 09-25-2013 03:17 AM
If you’re using a spar varnish that’s oil based, the varnish will bring out the grain on it’s own. Hence, no need for the extra step of the shellac. The varnish will also bind to the wood better without the shellac. Using the shellac under the varnish outdoors may cause the varnish to need refinishing sooner.
Edit: Try to stay away from the urethanes like Helmsman. Also the marine varnishes will last longer.
View pintodeluxe's profile
pintodeluxe
5653 posts in 2807 days
#4 posted 09-25-2013 03:29 AM
1+ most finishes work as their own sanding sealer. I try not to mix finishes if possible.
They say shellac is universal, and is compatible with any finish. However, the only finishing problems I have had were with shellac as a base coat. The finish can crinkle if the air temperature is too hot, or exposed to direct sunlight.
