DeWalt 735 blade change.
Forum topic by RussellAP posted 09-24-2013 09:45 PM 1509 views 1 time favorited 13 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3103 posts in 2161 days
09-24-2013 09:45 PM
I think the second board I put through my planer when it was brand new was a 1×8 western cedar. One of the knots broke loose and chipped my blade or blades. Anyway, I’m tired of sanding that damn line out so I need to turn the affected blade over.
Wanted to know a couple of things.
1. has anybody had any trouble with those screws. Do they strip the tool or are they pretty tight?
2. A quick browse through Amazon.com for replacement blades has the price all over the place. Are they all the same or should I get a special kind. I do only hardwoods now, no cedar goes in the planer.
If anyone is interested, here is an HSS set double sided for 35.99 no shipping with Amazon prime.
13 replies so far
View JustJoe's profile
JustJoe
1554 posts in 1913 days
#1 posted 09-24-2013 09:51 PM
Mine were like someone had welded them on, but I was told they’ve fixed that problem. That may be wishful thinking though. I was worried about stripping/breaking them but once I broke one head off using the wrench they give you (that POS that sits in the top) I realized babying it wasn’t going to help any either so I just chucked a star-bit in the drill to back them out (but not to retighten).
I can’t comment on the replacement blades, I’ve been using the ones Lowes sells until I save enough to put a carbide spiral cutterhead in it.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
RussellAP
#2 posted 09-24-2013 09:55 PM
That cutting head is in my future too. I’m in a position where I need to make 6 tables for an art gallery before Oct 4, and all this sanding is killing me.
View PurpLev's profile
PurpLev
8534 posts in 3523 days
#3 posted 09-24-2013 09:57 PM
I think they come out of the factory with someone (or something) impact-driving them in, so they are super tight and can strip easily if not extracted with care.
my way of taking them out without damaging them was to apply pressure inwards (pushing down hard on the wrench) as you twist them open – that way you relieve some of the stress from the bolt/threads and allow the bolt to come loose more easily.
all blades for the 735 are double sided unless stated otherwise (3rd party blades)
View pintodeluxe's profile
pintodeluxe
5545 posts in 2688 days
#4 posted 09-24-2013 10:01 PM
Get your air compressor out, and blow the dust out of the allen heads. That way your wrench will fully seat in the bolt. I never had any trouble changing blades.
I would recommend flipping all blades, rather than just one. If the blades are still sharp, and the nick is the only problem… you may be able to correct it by sliding the knives all the way to the side. Ie: nicked blade full left, good blade full right etc. However, the best bet is to change them all.
I source my blades from Home Depot or Lowes, and they are usually in-stock.
Good luck!
View teejk's profile
teejk
1215 posts in 2559 days
#5 posted 09-24-2013 10:48 PM
Do you have an impact driver on a cordless? If not do you have any other impact driver? You’ll save a lot of misery the first time you try to loosen them bolts…it’s are hard to keep the needed downward pressure needed to avoid stripping them out while you are also trying to spin them.
Just as an example (not related to woodworking)...my old Cub Cadet needed a tear-down that required bolt removal…I hit it with liquid wrench and HOT torch…several times…thinking I was going to have to drill them out anyway, I hit them with an air impact wrench. I was able to bear down and let the tool do the spinning. Seconds later I was done with all 8 bolts.
View rrww's profile
rrww
263 posts in 1988 days
#6 posted 09-24-2013 11:05 PM
First thing is to get a good high quality bit this will make a world of difference on any hard to loosen nut or bolt.
View Redoak49's profile
Redoak49
3017 posts in 1863 days
#7 posted 09-24-2013 11:40 PM
I do not know which bolts you have in yours. I had the old style which were very difficult to get out and ended up buying a new set of bolts which are Torx headed.
I bought my replacement blades from Infinity and think that they are much better than the DeWalt
View steviep's profile
steviep
233 posts in 2522 days
#8 posted 09-25-2013 02:15 AM
Not familiar with that particular planer and if they can be resharpened, but I get my blades for my grizzley planner resharpened down off of 31st and southwest Blvd for like $15. If you need more info pm me.
-- StevieP ~ Micheal Tompkins - you were not here on earth long but left a giant mark on us. RIP Brother
RussellAP
#9 posted 09-25-2013 03:14 AM
What’s the name of the place Stevie?
View lumberjoe's profile
lumberjoe
2894 posts in 2123 days
#10 posted 09-26-2013 03:04 AM
Russell, here is a good tip. Your planer has 3 knives. I’m not sure how the DW knives seat, but on most planers there are little nibs that stick up and you put the knife on. the knives have elongated holes. Instead of flipping or replacing them, Slide each knife over in the opposite direction a bit. The nick won’t be perfectly aligned anymore.
Since the nick is in a different spot on each blade, the next blade will clean up the nick left by the previous one. I tripple the life of my knives by doing this trick
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 1947 days
#11 posted 09-29-2013 02:26 PM
+1 lumberjoe If you look at the factory blade, it actually has a little triangle on it. I always start all three blades all the way to the left, with the triangle pointing right. Then I slide a blade to the right when a blade gets a nik. After all three are are slid, I flip them, and justify to the right, now the triangle is pointing left, and I repeat until replacement. I wrote this in sharpie under the cover to remind me.
P.S. The downside to the 735 is not having re-sharpenable blades. I have had the most success with factory blades, and paid about the price you posted.
-- Who is John Galt?
View cutmantom's profile
cutmantom
401 posts in 2910 days
#12 posted 09-29-2013 03:37 PM
you can also run the board twice each in a different spot relative to the nick in the blades, not a perfect solution but better than sanding
RussellAP
#13 posted 09-29-2013 07:42 PM
I reversed the blades and got an extra set. Cant afford to have a nick while I’m in production mode.
