Disk sanders
Forum topic by Loren posted 09-24-2013 08:16 AM 1424 views 0 times favorited 18 replies Add to Favorites Watch
View Loren's profile
10269 posts in 3615 days
09-24-2013 08:16 AM
I’m doing compound joinery. Crazy stuff.
I always thought disk sanders were kind of lame, like a tool you
used if you really sucked at woodworking.
Now I’m looking at these compound joints in chairs
and I’m thinking “how much do I need to spend?”
I’m look at the HF stuff, but there’s some stuff about
the plates not being flat and stuff like that. I’d like to
know what you think.
18 replies so far
View 1yeldud1's profile
1yeldud1
301 posts in 3009 days
#1 posted 09-24-2013 09:25 AM
i purchased a JET 12 inch disc sander several years ago and I have been very happy with its results and performance.
View Tony_S's profile
Tony_S
857 posts in 3050 days
#2 posted 09-24-2013 09:43 AM
” I’d like to know what you think.”
I think they’re lame.
The three different disk sanders Ive used over the years all sucked. Size ranged from about 12” dia, to 18” dia.
The paper bungs up to quickly and it was always a pain in the ass to change.
I’d recommend a cheap bench top edge sander before a disc sander.
Most of the BT edge sanders come with a small disc sander as well. Make a lamp base out of it….that’s all they’re good for.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View RussellAP's profile
RussellAP
3103 posts in 2253 days
#3 posted 09-24-2013 10:42 AM
I have one from HF with a belt sander, I never use the disk, didn’t even put it on in fact. The handiest thing I have for compound stuff is my spindle sander. Takes more talent to use too. lol
View scotsman9's profile
scotsman9
134 posts in 1856 days
#4 posted 09-24-2013 10:56 AM
I’d have to agree with Tony and Russell, edge sander and spindle sander is the way to go. Rigid makes one that has both for $120.00 at Home Depot, HOWEVER; I do not own it and have no review to offer. Only reason I mention it, I was in the store yesterday and spied it. Looked like a decently built product.
(not a HD shopper, popped in to grab a $3.00 paint roller).
-- Just a man and his opinion.
View mtenterprises's profile
mtenterprises
933 posts in 2660 days
#5 posted 09-24-2013 11:22 AM
If you go back through many of my postings you will note that I am an advocate of building your own tools. A disk sander is easy to build. Over the years I have had a free standing disk sander made from a washing machine motor with a pulley mounted to a particle board disk, various disk mounting systems on my lathes and even a steel disk mounted on the table saw all worked well for what a disk sander was used for. Of course the steel disk was the easiest to change the paper since you just took an old chisel and cut the paper and glue off while running. And this disk steel disk sander system had the advantage of being able to have two grits running at the same time. Oh yes, and the better quality sanding paper/cloth gives you longer use.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View semi75's profile
semi75
78 posts in 2867 days
#6 posted 09-24-2013 11:46 AM
I have the grizzly combo sander and I can tell you I would not get that one. The disc is ok but I’ve really only used it on aluminum, sad to say. The belt come in handy every great once in awhile. I do love my cheap Triton spindle sander which is basically the same things at the Rigid spindle sander mentioned above.
View shipwright's profile
shipwright
7966 posts in 2765 days
#7 posted 09-24-2013 11:53 AM
I agree with you Loren that a disc sander will make your compound angles perfect. I also agree that they can be a pita but that’s because they have to be understood and treated like sanders not chippers. If you use them to carefully perfect a compound angle they will excel. If you try to grind one down from a square piece, yes they will burn, plug, etc.
In your part of the country you can buy a used ShopSmith very cheaply. They have adjustability and fine tuning options not available on normal disc sanders. Even an old 10ER will give you great control and fine touch.
Have a look at the way I did the critical mitres in my Facets project here to see what I mean.
I don’t think they are just for people who suck at woodworking. ...... :-)
View crank49's profile
crank49
4030 posts in 2938 days
#8 posted 09-24-2013 03:03 PM
I have the large 12” disk sander from HF and it works very well.
I didn’t like the looks of the slightly smaller 10” machine at HFand after reading several negative reviews I believe that is the one people have trouble with.
The folks who think a belt sander is superior are not after accuracy, they are wanting to hog off a lot of material. A belt is much better for fast production of saw dust. Because the surface area of the belt is greater than the disk the paper will last longer and run cooler. But, because the abrasive is sliding across the supporting platen it moves and floats and looses some accuracy.
The disk sander, because the abrasive is glued to the solid disk, is much more accurate. At least it is if the disk itself is accurately ground and the motor shaft is tight with minimal or no run out. But as Paul pointed out, the paper will be more prone to gum up and burn. Also, because it is glued on it is a PIA to change.
A good item to have with a disk sander is one of those large gum rubber blocks for cleaning the paper. Makes it much more useful. HF sells these also, and they work great.
I will say that the table on the 12” HF machine is aluminum and not very well supported. The Rikon 12” disk sander is all cast iron, even the table, and it also has a brake to stop the disk. I wanted to get the Rikon but missed the sale when I could have gotten it for ~$120. The HF was plan B, but it’s been a good machine and I only paid about $90 for it on sale.
View Toolz's profile
Toolz
1004 posts in 3709 days
#9 posted 09-24-2013 03:12 PM
I also have the 12” Central Machinery one from Harbor Freight and love it. Here is my review:
http://lumberjocks.com/reviews/1614
Tip: once you remove a used disc fold a piece of wax paper and place it against the platen and rotate it by hand so the new disc covers half of the wax paper it; as you do this the new disc keep rotating until you have the sticky side of the disc against the platen and lined up. Then keep rotating and remove the wax paper. Doing it this way keeps you from having to remove the table to replace a used disc. ;-)
-- Larry "Work like a Captain but Play like a Pirate!"
View wiswood2's profile
wiswood2
1138 posts in 3663 days
#10 posted 09-24-2013 04:10 PM
Don’t go any smaller than 12”
Chuck
-- Chuck, wiswood2 www.wisconsinwoodchuck.com
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3552 days
#11 posted 09-24-2013 04:47 PM
I have a dedicated twelve inch disc sander and can go up to eighteen inches with the aid of my lathe, but twelve inches is and has been enough to do most things around the shop .It is more important it has real torque and does not bog down with a heavy cut.I removed the felt covering (hook and loop) and cleaned it up so it has just an aluminium disc.I did this as I had too large a pile of glue ons to throw away. Alistair
View moke's profile
moke
1154 posts in 2743 days
#12 posted 09-24-2013 05:04 PM
I have the delta 12” and have used it for many things. It can be too aggressive unless u use the finest grit. I can’t remember what grit I have on it, I just remember I got it from Kingspor and it was as fine as I could find. I did that because I was putting 45* segments meeting in the middle of a pen blank. (They become scallops after turned). I was told my disc sander was the way to do this. I was skeptical but with a crude jig it works very well. With the finer grit ( and it still isn’t all that fine). It is easy to manipulate and I get a good smooth glue edge.
Mike
-- Mike
View bigblockyeti's profile
bigblockyeti
5095 posts in 1687 days
#13 posted 09-24-2013 05:53 PM
You can always look for a good used one. Some of the older Deltas and Rockwells are very heavy which can help dampen any vibration and keep the thing from moving around on you if you’ve got a heavy work piece you need to sand. Steel or iron platens are better than aluminum too.
View Lee Barker's profile
Lee Barker
2170 posts in 2817 days
#14 posted 09-24-2013 06:05 PM
Lots of good opinions here.
If you build your own, perhaps a Shopsmith disk would go on the motor shaft? Or were those 3/4” on the 10ER? (Mine is at my son in law’s place; can’t measure.)
A friend has an old PM sander and it is so sweet, no vibration. I think that would be the goal whether you’re building your own or purchasing.
I recently picked up an old cast arn Tool King (disc-belt) and mounted it on a Rockwell pressed steel stand. I had to add ply panels to the steel to get it to settle down. I think a weighted wood stand would be superior. Vibration on this is a 3.5 on a 1 – 5 scale, 5 being Seiko, 1 being Harley Sportster.
This one has no dust collection accommodation and the dust gets around like the sniffles in a preschool. I don’t see a good way to ameliorate this.
I could do the kind of tuning you’re talking about, Loren, on my Ritter 4×132 but it had to go away to allow Joe’s Jet 6×48 in the shop. The latter, though I’ve spent a few hours tinkering with it, just vibrates too much for good precision work.
I’d look for a 12 or larger disc only with small footprint and hefty table adjustment. You’ll become adept at disc changing; it’s not all that bad.
Kindly,
View distrbd's profile
distrbd
2252 posts in 2413 days
#15 posted 09-24-2013 07:03 PM
The main part of a disk sander is the table attached in front of it ,if it is not anchored well it will move .
I bought an inexpensive 12” DS with a flimsy table that couldn’t hold 90 Degree while the sander was running ,all it needed was beefier /heavier attachment so I tapped the bolt holes to take 3/8” bolts,added a couple of spring washers which enabled me to crank it really tight and now the table won’t budge, it’s one of the most used $ reliable tool in my little shop.
It also helped when I replaced the adhesive back sandpaper to hook & loop type,changing paper grit is fast and easy now.
-- Ken from Ontario, Canada
