Removing Gorilla Glue
Forum topic by Puzzleman posted 09-24-2013 01:51 AM 1213 views 0 times favorited 4 replies Add to Favorites Watch
View Puzzleman's profile
Puzzleman
417 posts in 2940 days
09-24-2013 01:51 AM
Topic tags/keywords: glue gorilla urethane poly remove adhesive question
Have a project where someone used Gorilla Glue to glue plastic to metal. The plastic popped off but have the glue residue left over. What would you suggest to remove the glue?
-- Jim Beachler, Chief Puzzler, http://www.hollowwoodworks.com
View Dallas's profile
Dallas
3599 posts in 2483 days
#1 posted 09-24-2013 02:08 AM
sand paper of the appropriate grit for the job.
View bigblockyeti's profile
bigblockyeti
5112 posts in 1716 days
#2 posted 09-24-2013 02:12 AM
I’ve had to use a razor scraper most times when Gorilla glue gets where its not supposed to be.
View Makarov's profile
Makarov
102 posts in 1801 days
#3 posted 09-24-2013 02:13 AM
If you sand it use à facemask
-- "Complexity is easy; Simplicity is difficult." Georgy Shragin Designer of ppsh41 sub machine gun
View realcowtown_eric's profile
realcowtown_eric
608 posts in 1932 days
#4 posted 09-24-2013 03:04 AM
I’ve ben regluing a lot of chairs these days using the poly urethane glues. a good sharp chisel does a good ob of removing the sloppy foam , Then a light touch with a cabinet scraper, but most of the stuff I’ve been doing has some remnant of a finish, so it chips off prettty neatly.
If scratching the metal is a problem, you could always try wiping the surface with an oil, or using laminate sample chips broken in half….the edge is hyper sharp…and using that to clean u[.
Good luck.
Eiric
-- Real_cowtown_eric
