Looking for 12 Inch F Style Bar Clamps
Forum topic by MT_Stringer posted 09-23-2013 07:44 PM 1128 views 0 times favorited 8 replies Add to Favorites Watch
View MT_Stringer's profile
MT_Stringer
3173 posts in 3348 days
09-23-2013 07:44 PM
Topic tags/keywords: question
My work table has 7/8 inch holes drilled for bench dogs. I would like to find four clamps that I can insert up through the hole in the 2 inch thick top so I can clamp things in place.
What I am looking for is a clamp without the spring clutch. I have some of these and they are a pain to work with. The other requirement is the hole diameter (7/8 inch) the shaft must fit through.
If you have any that fit the criteria, I would like to hear from you. I plan to grind the end of the shaft off so the clamp can be pulled apart (and reassembled quickly)
Note: One option I have is to use pipe clamps with shorter lengths. That does work but I would prefer to use the bar clamp.
Thanks. Pictures and links are a plus.
Mike
8 replies so far
View Loren's profile
10477 posts in 3765 days
#1 posted 09-23-2013 09:13 PM
MT_Stringer
#2 posted 09-23-2013 10:13 PM
Dammit, Loren, that is a perfect cure for my ailment. Especially since I already have clamps I can dedicate to this modification.
Thank you very much.
Mike
#3 posted 09-23-2013 10:20 PM
Let me know how it goes. I have a 3” thick table with a pattern
of 7/8” holes in it into which I drop pins made from pipe, but
I would like to try clamps as well.
MT_Stringer
#4 posted 09-23-2013 10:23 PM
Will do. I will post a pic or three when I get them modified.
MT_Stringer
#5 posted 09-28-2013 03:47 PM
My clamps have been modified. Thanks go out to Loren for the suggestion.
Here are some pics. They are working as advertised. :-)
Note: I bought some large washers to support the bar under the table. If the pop rivets fail, I will switch them out to small bolts and lock washers.
Two of the clamps are the cheep Harbor Freight style. The chrome ones are Craftsman that my dad used back in the 70’s. They are similar in style and made with much better constructed,
View Dallas's profile
Dallas
3599 posts in 2604 days
#6 posted 09-28-2013 04:58 PM
MT_Stringer Maybe I’m a bit dense, but why the cross bar on the bottom?
MT_Stringer
#7 posted 09-28-2013 05:12 PM
Dallas, my workbench is 2 inches thick. This lets me insert the clamp, pivot the cross bar and clamp away…out in the middle of the table.
Dallas
#8 posted 09-28-2013 05:31 PM
Try to use it like a regular holdfast except put the shaft right up against the work piece, tap it with a hammer on the end and see if it will hold.
I have a a strip on an assembly table that is 1 1/2” thick where I added a chunk of 1” maple underneath. The holes are 13/16” and that seems to work well for me.
