Saw Push Sticks
Forum topic by MrRon posted 09-23-2013 07:06 PM 1728 views 1 time favorited 4 replies Add to Favorites Watch
View MrRon's profile
MrRon
4764 posts in 3240 days
09-23-2013 07:06 PM
Topic tags/keywords: tip
I use wood push sticks to push stock past the blade when ripping. One size stick doesn’t fit all. Sometimes I need to rip strips as thin as 1/8” and my push stick is 1/2” thick. That results in trashing a 1/2” stick.
Using a piece of 2×4x 8” long , cut the shape of the push stick on the bandsaw, you can then run the piece through the table saw or bandsaw to the desired thickness. You could cut 1/2”, 3/8”, 1/4”, etc. Attached is a sample push stick, but feel free to make it any shape you wish.
View William's profile
William
9949 posts in 2839 days
#1 posted 09-23-2013 07:13 PM
I run into the same issue at times. However, I’ve never put that much thought into it really.
Since I make several at a time out of scrap stock anyway, I don’t mind keeping one or two chewed up for thin stock.
When it completely tears apart, I keep a pattern in a drawer under my bandsaw so I can quickly cut another one or ten I them.
View BigMig's profile
BigMig
439 posts in 2610 days
#2 posted 09-24-2013 04:45 PM
Make one (or several) out of thin MDF… inexpensive, easy to work, etc.
-- Mike from Lansdowne, PA
View bondogaposis's profile
bondogaposis
4727 posts in 2348 days
#3 posted 09-24-2013 06:00 PM
I have a couple made out 1/4” mdf for thin stock.
-- Bondo Gaposis
View bigblockyeti's profile
bigblockyeti
5112 posts in 1717 days
#4 posted 09-24-2013 07:28 PM
I made a couple nice ones from black walnut, shaped very comfortably, rounded over the edges and finished with Danish oil. The bottom has a slot cut into it to accept a replaceable contact surface, so if it gets cut, it doesn’t matter, the sacrificial part is 3/4” wide by 1” tall and the length of the bottom which is about 16”.
