looking for advice on a jointer
Forum topic by David Theller posted 09-23-2013 12:31 AM 1937 views 0 times favorited 21 replies Add to Favorites Watch
View David Theller's profile
David Theller
34 posts in 1925 days
09-23-2013 12:31 AM
Topic tags/keywords: jointer
Up until now i have been doing my jointing on a 1956 Shop Smith with a small 4 inch jointer, however this morning I found that it is not working, slow to start, followed by a grinding noise, followed by the power strip fuse blowing. I am now looking for a used jointer on a small budget. I thought I would turn here to see if you guys could give me some advice on models.
Size and power recommendations would be very helpful.
Any advice is very much appreciated.
-- if at first you don't succeed, get the bigger hammer
21 replies so far
View lateralus819's profile
lateralus819
2241 posts in 1855 days
#1 posted 09-23-2013 12:40 AM
Ever thought about doing it by hand? It’s quite rewarding and doesn’t take much time at all. Could probably nab a #8 fairly cheap. Just a thought.
David Theller
#2 posted 09-23-2013 12:46 AM
I have tried, but with unsatisfactory results. I only have a #5s and #4s. Would the #8 make a great difference?
View Craig's profile
Craig
28 posts in 2549 days
#3 posted 09-23-2013 12:53 AM
I bought a used Jet 6” JJ-6CSX off CL a few years ago, and I’ve been happy, except I wish it was an 8”. Made a planer sled for wider boards. I have a #7 that gets used frequently as well.
I’d get the biggest you can afford or fit in your shop.
lateralus819
#4 posted 09-23-2013 01:09 AM
It helps with longer boards, but I’m sure it will do. Heres a video that helped me TREMENDOUSLY. I mean it, until i saw this i couldn’t figure out what i was doing wrong. http://www.youtube.com/watch?v=TJfD0-fFAzI
I always thought to just run down the board, apparently i have tendency to take off more on the left side.
food for thought. Alot quieter too ;)
A used #8 goes for about $125.
View gfadvm's profile
gfadvm
14940 posts in 2655 days
#5 posted 09-23-2013 01:39 AM
There was an 8” Grizzly, spiral cutterhead, and 6’ bed on Tulsa CL tonight for $500. This is a rare bargain! And it looked almost new!
View HorizontalMike's profile
HorizontalMike
7749 posts in 2879 days
#6 posted 09-23-2013 01:54 AM
Dave,
If you are going to go the hand plane route, I would suggest trying to find a large wooden jointer. They are much, much lighter to use and can do a great job.
Here is my 22in Auburn with its big thick blade.
NOTE: The biggest issue with going the hand plane route is to have a good sharpening routine and/or system. Planes that are not sharp, or are not sharpened correctly can be a great source of frustration.
Other than that, CL has 6in jointers all of the time. Boatloads of folks start with a 6in and then move up to an 8in or larger, so they end up selling the 6in on CL. As @gfadvm points out, on occasion you may see an 8in pop up on CL. AS a matter of fact, that is exactly how I scored my 8in spiral head Grizzly G0593. I paid $700 for it when it was just 2yr old at the time. Keep your eyes out and good luck.
David Theller
#7 posted 09-23-2013 02:20 AM
First, thanks for all of the advice.
Laterlus, I would like to start using hand tools more and more. Thank you for the video, it’s amazing all the information on YouTube.
Craig, Space is a concern, but not a major one. do you mind asking what price range you got it for?
gfadvm, sounds awesome but to get my truck out there and back would double the cost!
Mike, i have been looking at getting a never wooden plane, I picked up an older one however the blade wedge is very worn/cracked.
CL has several that look decent, however I would of course want to look at them further. Can you suggest any of the better brands?
HorizontalMike
#8 posted 09-23-2013 02:14 PM
Dave,
Here are a couple of ideas, since you truly want a “user”. I personally would find an old wooden plane 22-26in long with a good thick blade such as what I posted. From there I would rebuild a laminated plane around that blade with new lumber using the original plane as a guide. Building a laminated plane makes the cuts much simpler to do correctly.
Similar to these kits:
Ron Hock Kits
Making your own from scratch:
David Finck -- Making and Mastering Wood Planes
View MisterBill's profile
MisterBill
411 posts in 2217 days
#9 posted 09-23-2013 07:55 PM
Dave,
Where are you located?
View pintodeluxe's profile
pintodeluxe
5620 posts in 2779 days
#10 posted 09-23-2013 08:29 PM
Jet 6” jointer on a budget. I had one and it worked well, except it was often not wide enough.
Now I use a Delta DJ-20 8” jointer. It has 1-1/2 hp which is plenty. The extra bed width and length make it much easier to handle most boards I come across.
View firefighterontheside's profile (online now)
17944 posts in 1822 days
#11 posted 09-23-2013 09:39 PM
I bought a 6” grizzly that was about 20 years old for $225. I think I should have paid less, but they didn’t come up very often. I feel that the 46” bed is perfect for what I do. Longest thing I expect to joint is a 6ft table plank. So I would think in the range of $150 – $225 for a 6“.
David Theller
#12 posted 09-23-2013 10:36 PM
Sorry, college has gotten in the way of playing in the wood shop.
Mike, I will be looking into that book, making a plane has been a dream of mine. what would be the best lumber to use?
Master bill, I am in central Ohio, south of Columbus.
Pinto, a 6” would be a great step up, the bed on the little thing I have been using is less than 30”
Bill, the ones i was seeing on CL were closer to $500 for anything that was decent, both were deltas
HorizontalMike
#13 posted 09-23-2013 11:14 PM
Dave,
David Finck takes you through all the steps of selecting the best wood and building. Follow the link I posted above and select the video link (on the second line of text). That should answer give you a better idea of what is expected and offered.
#14 posted 09-26-2013 01:52 PM
When I bought mine there was a delta on Cl for 350, but I was trying to spend 200. Keep looking for a while, you should be able to find something.
View Bogeyguy's profile
Bogeyguy
548 posts in 2033 days
#15 posted 09-26-2013 02:11 PM
LOL! You had your Shop Smith joiner plugged into a power strip? You may want to upgrade for the new joiner when you get it.
-- Art, Pittsburgh.
