Biscuit jointer ??
Forum topic by Belg1960 posted 09-22-2013 06:00 PM 1823 views 0 times favorited 11 replies Add to Favorites Watch
View Belg1960's profile
Belg1960
1068 posts in 3062 days
09-22-2013 06:00 PM
Topic tags/keywords: question joining
Guys, I’m having no luck using my biscuit cutter to cut two different angles on the ends. The joint is 110 degrees on one side and 79 degrees on the other. I keeping getting the cuts in the wrong place. How do I set my joiner correctly to make these cuts? Also does it matter from which side the cut is made? I’m referencing both cuts off the outside face.
-- ***Pat*** Rookie woodworker looking for an education!!!
11 replies so far
View BArnold's profile
BArnold
175 posts in 1830 days
#1 posted 09-22-2013 06:26 PM
The photo you posted looks like a 90° angle made with two 45° cuts. No problem making biscuit slots on that kind of miter. Can you clarify your issue with a different photo?
-- Bill, Thomasville, GA
View Dallas's profile
Dallas
3599 posts in 2484 days
#2 posted 09-22-2013 06:33 PM
79 + 110 would make 189°? How is that working out for ya?
4985 posts in 2491 days
#3 posted 09-22-2013 06:44 PM
Does your biscuit jointer fence have a 135º setting (not all of them do)? The fence will look like it’s pointing at the floor. That’s what you need, then your reference to the outside face. That does look like a 90º joint, how did you get the 79 1nd 110º angles you mentioned.
Belg1960
#4 posted 09-22-2013 06:51 PM
Ok I got some more info and pics to explain.
The highlighted joint is what I’m reproducing for a Halloween version
This is how the joint lines up with my try
just a mock up of the joint
Belg1960
#5 posted 09-22-2013 06:53 PM
I just used that pic to describe the type of joining I was trying to accomplish.
First post edited
Belg1960
#6 posted 09-22-2013 06:59 PM
My references of the angles were how they were cut from 90 degrees. 11 Degrees shy of 90, and 20 degrees over 90 on second piece. Plz let me know how to state this more accurately for future projects. Thanks Notice the end tagline on my posts,LOL
10385 posts in 3645 days
#7 posted 09-22-2013 08:39 PM
The more acute joint will have more surface area. Shifting the error
to the outside, you can plane off the excess wood after assembly
without much trouble. If you make both angles the same the
surface areas will match up. So, if you want a 45 degree joint,
cut each part to 22.5 degrees.
You can only rely on the joiner fence to accurately index both
parts to the same biscuit depth if the angles are the same. It’s
a pivot point issue I think. You can analyze the error and
stick a shim under the jointer fence for one of the cuts
too, if you want to. That would be another way to solve
the problem on the outside, but you’d be shifting the thing
that’s bugging you to the inside of the joint, which is often
unacceptable as well.
Belg1960
#8 posted 09-22-2013 08:46 PM
Loren your saying my problem lies in the way I cut the two angles? If I would have split the difference between the 20 and 11 and made each 15.5 the cut would have wound up in the same place?
View SamuraiSaw's profile
SamuraiSaw
515 posts in 1962 days
#9 posted 09-22-2013 09:31 PM
As loren pointed out, different angle cuts result in disparate bevel face sizes. Determining the angle, dividing it in half, and cutting the miter the same on both pieces is the correct way. That would also eliminate the issue with the plate joiner.
If you’re stuck with what you’ve got, the plate joiner can be made to work but it will be a little trickier. Draw a reference line across the face of each cut and manually align the joiner face.
-- Artisan Woodworks of Texas.... www.awwtx.com
Dallas
#10 posted 09-22-2013 09:59 PM
Like the others said, when cutting angles, what you have to do on one side must be done on the other side in order for the edges to be equal.
Visualize it this way:
If you have a 4 sided box, each miter will be 45°
45+45+45+45 = 180°x2 =360
If you have an 8 sided box, each miter will be 22.5°
22.5+22.5+22.5+22.5+22.5+22.5+22.5+22.5 = 180°x2 =360
a 6 sided box would be 30°
A 10 sided box would be 18°
and so on.
Every miter must be divided into 360° in order for it to make an equal sided box.
(EDIT OOPS! MY THNKING WAS A BIT OFF< I PLEAD NOT BEING FULLY AWAKE AFTER MY NAP!)
View dhazelton's profile
dhazelton
2767 posts in 2294 days
#11 posted 09-22-2013 10:13 PM
Your first picture looks like you used some L brackets bent outward in the bottom corners. Is that correct? Anyway, you need to put an angle finder against the outside of each assembled corner, then hold that up to a protractor – THEN divide by 2. That’s how each leg of your corner should be cut. But it’s a Halloween decoration – don’‘t obsess for now and just use some angle or screws or whatever get’s you through the project. In the future remember that all the corners add up to 360 degrees and each angle is comprised of two equal parts. A protractor from staples or the art supply store will be your friend in this instance.
