glue for cedar
Forum topic by Howie posted 09-22-2013 03:06 PM 1543 views 0 times favorited 9 replies Add to Favorites Watch
View Howie's profile
Howie
2656 posts in 2799 days
09-22-2013 03:06 PM
I plan on lining a blanket chest(oak) with cedar closet liner. I was going to “tack” it with pin nails and put a dab of glue on it also. My intent was to wipe the ends with laquer thinner and then use Titebond 3 .
Anyone see a problem with this? All comments are welcomed.
-- Life is good.
9 replies so far
4830 posts in 2369 days
#1 posted 09-22-2013 03:34 PM
I see no problem with your plan. I’m guessing the liner you’re using is the thin boards as opposed to the stuff that looks like flakeboard. I built one some years ago using the liner boards, and simply put a small brad in the center of each board. It has held up well over the years. I don’t think the lacquer thinner is needed, but it’s not going to hurt anything either.
View AlanBienlein's profile
AlanBienlein
159 posts in 2550 days
#2 posted 09-22-2013 03:37 PM
What is the purpose of the lacquer thinner. Just glue it. Here are two examples of projects I did using aromatic cedar. The desk was done with titebond II and the tool cart was done with titebond III.
View Charlie's profile
Charlie
1100 posts in 2162 days
#3 posted 09-22-2013 04:54 PM
I use pre-foamed gorilla glue when I make flutes out of aromatic red cedar. :)
View rrww's profile
rrww
263 posts in 1989 days
#4 posted 09-22-2013 05:12 PM
I just use Titebond II – never had a failure yet.
Howie
#5 posted 09-22-2013 05:20 PM
Thanks for the comments.
I just figured that cedar being kind of oily(??) I should clean it first. Appears like that isn’t necessary.
@Fred: yes the planks not that other stuff.
Thanks again
-- Life is good.
Rick Dennington
5659 posts in 3070 days
#6 posted 09-22-2013 07:33 PM
Howie,
Sounds like a plan to me…...Are you just doing the bottom of the chest or the whole thing…? You could always just use pocket hole joinery, and avoid a lot of glueups…..Remember, glue is like Brylcreem….a little dab’ll do ya…..!!!!!!!!!
-- " Don't pet the sweaty things, and don't sweat the petty things."
Howie
#7 posted 09-22-2013 11:10 PM
Thanks Rick, I’m just going to line the inside walls. I just thought a little “dab” of glue might be in order in case one of the pin nails popped loose.
Besides the slats on the closet liner aren’t thick enough for pocket screws.
-- Life is good.
Rick Dennington
#8 posted 09-23-2013 12:46 AM
Got it, Howie…....I guess that takes care of that…...lol…....!!!!!!!!!!!!!!
View Jim Jakosh's profile
Jim Jakosh
19966 posts in 2981 days
#9 posted 09-30-2013 01:19 AM
I use Titebond 3 on Cedar all the time. No problems!
