auxiliary table saw fence really necessary?
Forum topic by andrewscrolledcfafts posted 09-22-2013 03:24 AM 6018 views 0 times favorited 13 replies Add to Favorites Watch
View andrewscrolledcfafts's profile
3 posts in 1986 days
09-22-2013 03:24 AM
Topic tags/keywords: table saw auxiliary fence jig question
Whether I’m watching armature wood videos on YouTube or a woodworking show on cable, I see people use an auxiliary fence either permanently or clamped to the already existing fence on the table saw; why would another fence be needed? Sometimes the fence might be a jig; but mostly its just another fence. Also if I choose to use one, I’m assuming the face should be smooth and should I connect it permanently to the existing fence?
-- "Insanity: doing the same thing over and over again and expecting different results." - Albert Einstein
13 replies so far
View RogerInColorado's profile
RogerInColorado
321 posts in 1983 days
#1 posted 09-22-2013 03:34 AM
I know of only three occasions to use an auxiliary fence: (1)using a part of a dado blade and there is need to bury the rest in the fence (because you are cutting a dado on the very edge or very end of a board); (2)Cutting a bevel on a tall board or (3) using a accessory, such as cutting a tenon using a tenoning jig or cutting spline keyways in a box. There may be others, but I can’t actually think of a reason to leave an auxiliary fence mounted when it isn’t getting used.
18354 posts in 1885 days
#2 posted 09-22-2013 03:35 AM
I have a shop fox aluma classic fence which is aluminum on the outside. I have never used an auxiliary fence, but it has t slots so that you could if you wanted to. The reasons I know of are that the phenolic ones have less friction and allow the material to slide along it easily. When it wears out you can just replace it. If you accidentally touch the blade with it, it will be more forgiving than the metal touching. A reason for clamping one on temporarily would be for a sacrificial fence for rabbeting. Is this what you have seen?
View WayneC's profile
WayneC
13754 posts in 4126 days
#3 posted 09-22-2013 03:37 AM
They are used with Dado blades to make Rabbits, Also to make the fence higher for some operations. Usually they are removable and only used when you are performing operations where they are useful.
Check out this link for some examples….
http://www.rockler.com/how-to/woodworker-shares-a-few-new-uses-for-the-universal-fence-clamp/
WayneC
#4 posted 09-22-2013 03:38 AM
LOL. Looks like I was a bit slow in my response. :)
#5 posted 09-22-2013 04:09 AM
I did the same thing.
View MrRon's profile
MrRon
4800 posts in 3272 days
#6 posted 10-10-2013 09:51 PM
An auxiliary fence’s main purpose is to protect the normal fence from accidental saw cuts.
Rick Dennington
5913 posts in 3223 days
#7 posted 10-10-2013 10:43 PM
We have a winner….... Mr. Ron….....!!!!!!!!!!!!!!
View Mike C.'s profile
Mike C.
6 posts in 1267 days
#8 posted 04-21-2015 06:35 PM
ive also read that you can use a fence like this to create a jointer from your table saw.
jointer out of your table saw
-- Capt Mike
View Richard's profile
Richard
1916 posts in 2719 days
#9 posted 04-21-2015 06:42 PM
An auxiliary fence s main purpose is to protect the normal fence from accidental saw cuts.
- MrRon
And if you have a SawStop that accidental saw cut Would Trigger the Brake , and thats costs a lot of money when you have to replace it and the blade. So it can save you money.
View RobS888's profile
RobS888
2415 posts in 1874 days
#10 posted 04-22-2015 12:13 AM
- MrRon
- Richard
That doesn’t sound right, I’ll try turning mine on and sliding the fence to touch the blade and see if it lights, but I don’t think it will.
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
Richard
#11 posted 04-23-2015 07:35 PM
I think the blade has to be running for it to trigger and I don’t think you want to test it that way. I have touched the blade on the SawStop I have access to when it was not running and nothing happened , they even showed us that in the safety class that you could touch it with the power on but not with motor power on and running.
View Ghidrah's profile
Ghidrah
667 posts in 1251 days
#12 posted 04-23-2015 11:08 PM
I have a 4th reason, unless someone above already suggested it.
If ones fence isn’t straight, (concave/convex) an auxiliary fence could be used to correct the error.
-- I meant to do that!
View BroncoBrian's profile
BroncoBrian
556 posts in 1987 days
#13 posted 04-23-2015 11:16 PM
Rob is right, the blade does not have to be running to tell you if the contact would trigger the cartridge. The lights will tell you that. The SS fence will not trigger, it is made of material that will not conduct electricity.
Good question Andrew. I have seen the same and wondered. I never seem to be in danger of messing up my fence so it did not make sense to be plus it would mess up your ruler.
Dados make sense though.
-- I think foosball is a combination of soccer and shish kabobs.
