Friggin' Air comperssor won't drain......UUrrgg.....
Forum topic by Rick Dennington posted 09-20-2013 10:18 PM 4406 views 0 times favorited 57 replies Add to Favorites Watch
Rick Dennington
5807 posts in 3160 days
09-20-2013 10:18 PM
I have an Ingersol—Rand 36 gal., oil fed, belt drive compressor, and the damn thing won’t drain the water out of the tank…...I unplugged it, bled all the air out of the tank, and I noticed the water was “milky” looking…........Bled everything down to zero, unhooked the air hose, opened the drain cock valve, and nothing…...The tank has water in it, and can’t figure out why it won’t drain…..I’ve done this many times before with no problems…....What’s going on, and how do I get it to drain….?
57 replies so far
View johnstoneb's profile
johnstoneb
2869 posts in 2139 days
#1 posted 09-20-2013 10:24 PM
You’ve got crud in the bottom of the tank that has plugged the drain. You’ll probably have to take the drain valve out of the tank and use something to poke into the tank and loosen the crud.
-- Bruce, Boise, ID
View Bill White's profile
Bill White
4904 posts in 3927 days
#2 posted 09-20-2013 10:33 PM
Yep! Take the drain valve out, clean it well, get back to blowin’ stuff. Mine can get a little junk in it too.
Bill
-- bill@magraphics.us
Rick Dennington
#3 posted 09-20-2013 10:35 PM
Yep…You could be right…..I opened it all the way, and tried to use a small probe to check to see if it was plugged up…It felt like I was still hitting metal….So I didn’t push it any….
Rick Dennington
#4 posted 09-20-2013 10:47 PM
The thing is…I can’t even get one drip to come out when the valve is fully opened…...I’m a little concerened that the water is milky-looking…..Just hope it didn’t get any water up in the cylinders…It’s been a while since I changed the oil….Checked it not long ago, and it was full…..
johnstoneb
#5 posted 09-20-2013 10:59 PM
You’ve got to screw the drain plug out of the tank. Once you get it out you will see why it feels like you are hitting metal with the probe. because you are.
-- Bruce, Boise, ID
Rick Dennington
#6 posted 09-20-2013 11:11 PM
Yep…...it’ll take that to fix it right…...Hopefully that’ll do it…...”ppreciate it, guys…...I just needed some closure…....lol…....Thanks….......!!!!!!!!!!!!!!!!!
View ajosephg's profile
ajosephg
1880 posts in 3527 days
#7 posted 09-20-2013 11:24 PM
Hi Rick
I think the milky looking water is nothing to worry about. It’s just water mixed with the oil blow-by from the compressor. Like when water gets into the crankcase of a gas engine.
BTW, I drove by your town earlier this week, but was on a mission and couldn’t stop. :)
-- Joe
Rick Dennington
#8 posted 09-20-2013 11:31 PM
Thanks, Joe….I figured it was something to not worry about…the compressor runs fine, and has 135 PSI…...It just needs a good draining…..Sorry I missed you….but I would have anyway, as we were down in Texas, and just got back a couple of days ago…....Maybe next time….........!!!!!!!!!!!!!
View b2rtch's profile
b2rtch
4851 posts in 3014 days
#9 posted 09-20-2013 11:54 PM
the drain is full of rust, remove it and clean it
-- Bert
ajosephg
#10 posted 09-20-2013 11:59 PM
One of these days we’ll cross paths.
BTW – the way the drain cock is constructed prevents pushing a probe through it. As the other folks has said, you gotta remove it. You might put in an elbow and a short piece of pipe, etc. to make it easier to drain. Our old bones make it difficult to reach under the tank.
-- Joe
View Dallas's profile
Dallas
3599 posts in 2453 days
#11 posted 09-21-2013 12:34 AM
Open it, fire it up, let it blow out the crud.
That is what happens in auto repair shops every day.
Why over think it?
Rick Dennington
#12 posted 09-21-2013 12:36 AM
Thanks, Bert......Yea, that sucker is locked tighter than Dick’s hatband…...I got to go catch some fish tomorrow, so it’ll prolly be Sunday before I get on it…...’ppreciate it…....
Good point, Dallas…...
View gfadvm's profile
gfadvm
14940 posts in 2656 days
#13 posted 09-21-2013 12:46 AM
Have you tried opening the drain with the tank fully pressurized? Might blow the obstruction out. I think that is what Dallas said.
Shawn Masterson
1325 posts in 1915 days
#14 posted 09-21-2013 03:19 AM
DO NOT REMOVE THE DRAIN COCK UNDER PRESSURE!!!!!!!!!!!!!!!!!!!!!!
Bleed off the pressure completely remove the drain cock and throw it in the trash. take a probe and poke around in the tank carefully so you don’t damage the threads. now turn on the compressor and let it blow out the crap. cover the floor it will be nasty. Now go to the local hardware store and buy a 1/4” street 90, a 1/4”x 8” nipple and a 1/4” ball valve. Use those parts to replace the factory drain, so this never happens. also this makes it easier to drain the compressor so you are more likely to do it more often.
View C_PLUS_Woodworker's profile
C_PLUS_Woodworker
601 posts in 2873 days
#15 posted 09-21-2013 04:18 AM
Hi Rick…..
I just barely (yesterday) finished rebuilding the motor and pump on my compressor.
I had to learn a lot because this was all new to me.
I talked to several guys that I knew did know their stuff about compressors.
I think all the posts above about removing the entire drain plug are right on.
Re: Milky looking water:
I learned a few little tips…………
Oil could only come from the compressor rings, so keep a close eye on the oil level in your compressor. If it starts to use too much it will be time for an overhaul
Two other things to check before condemning the rings ………..first make certain that the crankcase breather is not plugged,
And secondly ……….that it is not over-filled.
Both of those situations can force the oil past the rings due to excessive pressure in the crankcase.
Maybe try different oil. Most compressor pumps recommend using a non-detergent oil. Synthetic is good, but it’s hard to find a non-detergent synthetic oil unless you buy one specifically made for compressors.
Too light of oil can also be a factor in blow-by
Just my $.02
Best to you and yours.
Bruce.
showing 1 through 15 of 57 replies
