Hand Plane
Forum topic by Straightpiped posted 481 days ago 307 views 0 times favorited 11 replies Add to Favorites Watch
View Straightpiped's profile
Straightpiped
81 posts in 499 days
481 days ago
Topic tags/keywords: plane question
I feel like I ask too many questions, but there is only one way to learn.
My father-in-law gave me an old Stanley#3 that belonged to his dad. From first glance it is in excelent shape. I bet is hasn’t been used in decades. 100% zero rust, except for the blade. True as can be. The problem that I have ran across that I can’t find any info about is the “Frog”. It isn’t parallel with the “Mouth”. I don’t know how to adjust this. If you are looking at it from the way you would use it, the right side of the “Frog” sits farther from the “Mouth” than the left side. Is the fixable? Is this even a problem?
Tyson
-- T. Nelson
View Peter O's profile (online now)
Peter O
1102 posts in 882 days
481 days ago
I don’t have that particular plane, but in most cases, if you remove the blade you’ll see two machine screws attaching the frog to the body. The screws are in slots which allows you to reposition and adjust the frog.
-- http://www.north40custom.com -- http://north40studios.etsy.com --
View Thos. Angle's profile
Thos. Angle
4176 posts in 970 days
481 days ago
Listen to Peter. It’s and easy fix. Take it all apart and clean it up and sharpen it. You will learn about it this way.
View HokieMojo's profile
HokieMojo
1286 posts in 736 days
481 days ago
Just pay close attantion while disassembling. Otherwise reassembly can be more of a challenge.
View CessnaPilotBarry's profile
CessnaPilotBarry
1539 posts in 710 days
481 days ago
As a counterpoint, I should mention that a really nice, old #3 might pay for several Lie Nielsen or Veritas planes.
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply choose to ignore the thread...
Straightpiped
480 days ago
Here is the plane…I have not done any cleaning at all.
As you can kinda see in this picture, the tounge and the frog do not line up parallel. This is with the screws loose and me trying to line them up.
-- T. Nelson
Peter O
480 days ago
Looks like it’s in pretty good shape. Looking at the photos, I can’t see any reason why the frog shouldn’t move a bit. Maybe a burr or something on the underside? We have a couple of hand-plane experts on LJ – maybe one of them can tell you why it won’t move.
I pulled apart the jack plane that I use the most and the frog is out of alignment almost as much as yours. I’m going to adjust it (it’ll bug me if I don’t), but it’s been cutting fine – I’ve used it a bunch this week.
teenagewoodworker
2627 posts in 776 days
480 days ago
ya i have the same plane its a really nice plane. you should be able to adjust it some too. i had to do that on mine and it worked fine. a burr is the only thing i can think of.
Thos. Angle
480 days ago
Peter asked me to come back and look at this again. This is a late model #3. If you look at the back of the frog, you will see a screw which is on the base but attaches to the frog. This will move the frog backwards and forwards. I’m not sure with out having it in my hand what is going on that you can’t get it to move. It looks very clean and should be easy to adjust.
HokieMojo
480 days ago
At a risk of stating what you already know (and building on what Thos. stated above), make sure you aren’t assuming that the screw behind the frog should be tightened all the way. That is just an adjustment screw, not intended to be screwed all the way in.
Straightpiped
480 days ago
Found out what the problem was. The screw that adjust the forward/backward movement of the frog has that “U” bracket that actually pushes/pulls the frog, that bracket was slightly turned. Adjusted that and now it lines up perfect.
Thanks for everyones help.
-- T. Nelson
View Bill White's profile
Bill White
141 posts in 968 days
479 days ago
That is one sweet plane. I added one to my collection about 3 yrs. ago (for $10.00 I might add). Needed a clean up and sharpening.
Bill
