Confusion on full overlay hinges and face frame cabinets
Forum topic by Scott C. posted 09-20-2013 08:12 PM 12570 views 0 times favorited 18 replies Add to Favorites Watch
View Scott C.'s profile
Scott C.
158 posts in 2080 days
09-20-2013 08:12 PM
I’m considering building my own kitchen cabinets and ordering the doors. The current plan is face frame cabinets with 1.5” rails and stiles and as little reveal as I can get away with. Ideally I’d like to use 1 3/8” overlay hinges, leaving an 1/8” reveal on an individual cabinet and 1/4” reveal when two cabinets are next to each other.
I’ve read that 1/4” reveal is the minimum before you start to have issues opening the doors. I’m confused, is this the reveal when two cabinets are placed together, or before they are placed together?
Can I use a 1 3/8” overlay hinge with 1.5” stiles, or do I have to stick with 1 1/4” overlay hinge?
Thanks!
-Scott
-- measure twice, cut once, swear and start over.
18 replies so far
View Loren's profile
10476 posts in 3677 days
#1 posted 09-20-2013 08:16 PM
35mm cup hinges?
View chrisstef's profile
chrisstef
17429 posts in 3035 days
#2 posted 09-20-2013 08:31 PM
I second the cup hinges. The ones I used attached nicely to the face frames in the inside of the box.
Id say its when they are placed together leaving you with a 1/4” gap between the two doors. You want to leave yourself a little bit of room there for adjustments. Im almost finished with the cabinet door replacement in my kitchen. If you have anything that I can help ya with just let me know. Here’s how the doors I ordered came out:
Ignore the Jim Beam .. I was doin a lil celebrating.
Scott C.
#3 posted 09-20-2013 08:41 PM
I believe they are 35mm, I’m looking at these: http://www.cshardware.com/b-39c355c-22.html
#4 posted 09-20-2013 09:09 PM
Oh, I see. Those won’t work with the kind of reveals you want. No
cup hinge will. The maximum distance from the edge of the 35mm
hole to the edge of the door is about 5/16”. If you set the hinge
in more to try to get a larger overlay, the hinge will bind.
I talked to a guy once who said he made “frameless” cabinets
with a 1” wide face frame. If you made the frame that narrow
you could get the effect you want and have some of the
benefits of face frames.
I do concede that doing proper frameless cabinets without
specialized machinery is tricky. I recommend Paul Levine’s
book on Cabinet making because his methods draw on
both face frame and frameless systems and he uses the
table saw and router to do almost everything and the
cases come out square and accurate enough.
Scott C.
#5 posted 09-20-2013 09:23 PM
So I could use something like this: http://www.cshardware.com/fr-et887141gg.html
and end up with 1/2” reveal when 2 cabinets are put together?
#6 posted 09-20-2013 09:31 PM
I might not be thinking clearly about that style of cup hinge…
it’s possible. Buy a pair and fool around with them. You can
download spec sheets from BLUM that will show what the
range is.
You can really get in trouble if you don’t do a range of motion
test with cup hinges before you get your doors made.
View DLawlessHardware's profile
DLawlessHardware
16 posts in 2114 days
#7 posted 09-20-2013 09:37 PM
Something to keep in mind is that the thickness of your doors will determine how much reveal is required before the doors bump each other as they open in the case of back to back cabinets.
-- D. Lawless Hardware http://www.dlawlesshardware.com
DLawlessHardware
#8 posted 09-20-2013 09:40 PM
Also, same hinge but cheaper: http://www.dlawlesshardware.com/overlayeuro.html
I swear I didn’t come here just for that reason, haha, but I couldn’t help it once I saw we carried that hinge.
View teejk's profile
teejk
1215 posts in 2714 days
#9 posted 09-20-2013 09:41 PM
Welcome to the confusing world of “hinge speak”.
“Overlay” means your doors are going to extend proud of the face-frame and refers to how much of your door extends beyond your face frame on the hinge side. “Reveal” is a different matter that is more a “flush” door thing.
So if you are using 1 1/2” stiles and want no part of the hinge side face frame to be seen you would go with 1 1/2 inch overlay hinges. If you want to see part of the face frame when the door is closed, then do the math…1” exposed face frame would dictate a 1/2” overlay hinge, 1/2” exposed face frame 1” hinge, etc.
On an overlay single cabinet I think you would want to center the door in the opening so say 1” face frame exposed on the hinged side should be matched with 1” exposed on the non-hinged side. Doubles require a little more math but the concept is the same.
View cabmaker's profile
cabmaker
1736 posts in 2838 days
#10 posted 09-20-2013 10:00 PM
Scott, why not just go frameless? Framless represents the epitome of simple when it comes to cabinetmaking.
I wouldn’t recomend the hinges your looking at for sure! Looks like they only crank 105 deg.(not enough for kitchen use)
a frameless job will not require highly specialized equip. Unless you intend to go mainstream competitive cabinetmaking.
JB
teejk
#11 posted 09-20-2013 10:19 PM
Cab…I agree but “frameless” requires getting some nice plywood (for whatever reason that stuff seems to be a rare commodity lately). And I’ll add that the hinge costs on the “frameless” is high (I pay <$1 each on the 6 way adjustables).
Scott C.
#12 posted 09-20-2013 11:05 PM
@ Teejk – I understand what your saying in your post, but what’s confusing me is that I’ve read multiple times “leave at least a 1/4 reveal”. Does a 1/4” reveal mean the distance between the outer edge of the door and the outer edge of the face frame it’s attached to, or the door and the door on the next cabinet?
@ Dlawless hardware – the doors are 3/4 thick.
What I want to use is 1 3/8” hinges with 1.5” stile, that would leaving 1/8” from the edge of the door to the edge of the face frame, and 1/4” from door to door. I just looked at some cabinets on display at lowes and that’s how they were set up.
I’ve thought about frameless, but I’m leaning towards pre-finished plywood and I don’t know if I trust it to stay flat. I’ve read the frameless guys prefer melamine for that reason, the melamine does a better job staying flat. Either way I’d want to put some hardwood edgeing on it and I figure the face frame will give me a little wiggle room with bowed plywood. That combined with cheaper hardware of face frame cabinets.
View Windowman's profile
Windowman
4 posts in 1742 days
#13 posted 09-20-2013 11:07 PM
I don’t think you will have a problem opening the door but at that price get some hinges drill some plywood or scrap and make sure. That’s a lot cheaper and you know the whole process before you drill your new doors and cabinets.
-- Just when you think your 10' tall and bullet proof Life knocks your feet out from under you and shoots you right in the chest
View DS's profile
DS
2926 posts in 2449 days
#14 posted 09-20-2013 11:18 PM
+1 to what Loren said. 5/16” is as close as you can get with those hinges before running into issues. With two doors, that makes a 5/8” gap. You can do less, but don’t expect to have two adjacent doors open at the same time without binding.
If you want a true full overlay cabinet you’ll need to go FRAMELESS and 1/8” gaps are commonplace in that world. It all has to do with the pivot point and the “throw out” on the hinge.
As my cousin said as I was adjusting doors on the cabinets in his new kitchen—“A Lexus fit” – uh huh.
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1757 days
#15 posted 09-20-2013 11:58 PM
Here are the specs on the 39C
110 degree opening hinge
It says 7/32” is the minimum gap. So if you have 2 doors next to each other you would have to have 7/32 in between them so they don’t hit each other. Also note, I’m pretty sure that is if you are opening 1 door at a time.
If you had a rounded corner on your door you cold get a little closer. Make a sample: Take a stile 3” wide and put 2 doors on it and see how it works out. Keep cutting the stile smaller to see how close you can get them before they hit.
Here it is a little closer
