Shop Made Set Up Blocks
Forum topic by MT_Stringer posted 09-20-2013 05:12 AM 1323 views 0 times favorited 7 replies Add to Favorites Watch
View MT_Stringer's profile
MT_Stringer
3154 posts in 3138 days
09-20-2013 05:12 AM
Topic tags/keywords: jig
While ripping a few boards today, I decided to make some set up blocks . I had a piece of 3/4 inch melamine coated shelving material (particle board core) so that is what I used.
For each block, I made trial cuts until I had exact results for each block. So far, I have 1 1/2 inch, 2 inch and 3 inch blocks. I measured each one with a digital caliper and they are right on the money. Pretty cool to measure a block and the result is 2. At 1/128 inch increments, that is close enough for the things I build. :-)
As I get busy building face frames for the cabinets that will go into our kitchen, I can set up my table saw to get repeated results every time.
No doubt there will be some larger blocks made to help me space out the drawer openings when I build the face frames.
Note: This cabinet building stuff is going to be a challenge but I feel confident they will turn out pretty nice.
I might add that I have a set of metal set up blocks but I like the idea of having my own custom set.
7 replies so far
View Handtooler's profile
Handtooler
1497 posts in 2039 days
#1 posted 09-20-2013 09:03 AM
Great tip! I hadn’t thought ogh using the larger sizes than the brass sets less than 1 inch. Would HDPE be stable enough to machine down for custom made smaller set? And what wood if any would be stable enough in heat/humidity changes to be used for these larger sets? As an example Lowe’s markets a three ply laminated solid oak length of square 2 1/2” stock for table legs and such. Could it be milled to various demensions for set-up blocks?
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View Roger's profile
Roger
20904 posts in 2711 days
#2 posted 09-20-2013 01:43 PM
Good ideas
MT_Stringer
#3 posted 09-20-2013 02:47 PM
@handtooler-you are asking the wrong guy about what to use for set up blocks. I use the first thing I see when I need to make one. :-)
Note: I have furniture that I built in the 80’s and it has only moved a few times…from Baytown to North Shore and then to Channelview…about twenty miles total in 25 years! :-)
Handtooler
#4 posted 09-20-2013 04:05 PM
Thanks for your reply, MT. LOL
View harry1's profile
harry1
523 posts in 2192 days
#5 posted 09-21-2013 03:31 AM
Good idea Mike but where are the pictures, you know that I like pictures!
-- Harry, Western Australia
MT_Stringer
#6 posted 09-21-2013 04:33 AM
Oh, Ok Harry. If you insist. :-)
They are 8 1/2 inches long…just what I had laying around.
Now I don’t have to measure, just set ‘em in place and set the fence.
View Nygiants77's profile
Nygiants77
57 posts in 1864 days
#7 posted 09-21-2013 04:43 AM
this is a good system but it will vary a little bit depending on how tight you lock the fence
