Just can't stop Blushing??
Forum topic by FrogpondWoodworks posted 09-19-2013 06:37 PM 1111 views 0 times favorited 2 replies Add to Favorites Watch
View FrogpondWoodworks's profile
FrogpondWoodworks
39 posts in 1843 days
09-19-2013 06:37 PM
I had a post on here a while back about the poly(clear satin) I was using. Had a lot of responses and my problem came down to the humidity and using a fast drying poly. Well, the humidity has went down, so I thought I would try to finish my project; a nosing piece for a floor step down. Once again it’s what one responder said was blushing.
I completely redid the piece last time and would really like to not do it again. Is there any way I can fix this? It’s the first coat of poly, wiped on. I was going to try to wipe it down after about 10-15 minutes but couldn’t get to it. Will subsequent coats fix it or just worsen the problem? I could really use some help on this. Trying to sell my house so I need to get these pieces done and put in place asap.
-- Rich, Kentucky
2 replies so far
View rrww's profile
rrww
263 posts in 2138 days
#1 posted 09-19-2013 09:30 PM
I didn’t see your first post so sorry if these are repeat questions.
How old is the poly?
Is it a non gloss poly? If so did you stir very good? Any finish that isn’t gloss has a flatting agent in it, if its not mixed well this can create problems with clarity. You have to keep mixing it, if it sits for very long it can settle.
Odds are if the first coat has a clarity problem adding more to it won’t do anything to fix it.
View jimmyjjohn's profile
jimmyjjohn
3 posts in 1892 days
#2 posted 01-07-2014 05:47 AM
I have a tutorial group and the tutor stares really directly into my eyes and I blush immediately- How to Stop Blushing ?
