glue open time
Forum topic by laflaone posted 11-21-2008 03:23 PM 1044 views 0 times favorited 8 replies Add to Favorites Watch
View laflaone's profile
laflaone
59 posts in 3585 days
11-21-2008 03:23 PM
I am ready to glue up the base of my new workbench. I will be gluing 8 mortices and tenons at the same time, then clamping. I need more than the 5 min open time for titebond II, and 8 min for tb III. they have a product called titebond extend, but i can’t find it in my area. (ft pierce/port st lucie, fl) any suggestions on another product with longer working time, but still has adequate strength?
-- "non illegitimis carborundum"
8 replies so far
Douglas Bordner
4021 posts in 3968 days
#1 posted 11-21-2008 04:29 PM
Liquid Hide glue would give you a longer open time, as would Polyurethanes, but with all the wracking forces I might avoid the latter.
View SteveKorz's profile
SteveKorz
2134 posts in 3618 days
#2 posted 11-21-2008 05:58 PM
I don’t know what kind of time frame you are looking for to get this thing glued, but if I were you, I would just order it on the net. You’d get it in a few days, and that way you could ensure the bond would hold, esp on something as important as a bench. Here's the link.
—Steve
View spaids's profile
spaids
699 posts in 3598 days
#3 posted 11-21-2008 06:19 PM
This is the stuff David Marks uses on his show. “Slow setting plasic resin glue” When he needs a long set up time. Maybe it could work for you. Half hour open time!
-- Wipe the blood stains from your blade before coming in.--
View fredf's profile
fredf
495 posts in 3614 days
#4 posted 11-21-2008 11:37 PM
Can you glue up sub assemblies?? That would make it easier than trying to do all at once
-- Fred, Springfield, Ma
laflaone
#5 posted 11-22-2008 02:02 AM
Thanks for your replys. I had posted the same question on the Sawmill Creek forum, and one of the posters recommended 2002 GF avaiilable from Lee Valley. I have ordered some. It has 15-20 minutes open time, and the shear strength is more than adequate.
teenagewoodworker
2727 posts in 3673 days
#6 posted 11-22-2008 02:10 AM
if i were you sub assemblies would be the way to go.
View dsb1829's profile
dsb1829
367 posts in 3532 days
#7 posted 11-22-2008 05:23 PM
Sub assemblies are the way to go. I haven’t done anything too elaborate yet, but I still use subs. Glue up the ends and dry fit the stretchers, then come back and glue the stretchers in another step.
-- Doug, woodworking in Alabama
laflaone
#8 posted 11-22-2008 07:32 PM
Thanks for all your replys. In answer to several posts, I have used sub assemblies. I did the ends first. I am ready to put in the long stretchers to join the ends. I could put in four stretchers in one end at a tiime, but I prefer to do both ends at once, and clamp. This eliminates a step which has the possibility for something misaligned. This was the reason for my original post, a longer working time. I am going with 2002 GF from Lee Valley, which has 15-20 min working time.
