Mineral Spirits
Forum topic by Straightpiped posted 366 days ago 217 views 0 times favorited 3 replies Add to Favorites Watch
View Straightpiped's profile
Straightpiped
73 posts in 384 days
366 days ago
Topic tags/keywords: mineral spirits finishing
I hear alot of talk about Mineral Spirits as a finish. I was at Ace Hardware yesterday buying some paint thinner cause I am painting a boat and its 100% Mineral Spirits. Is this the same stuff?
Tyson
-- T. Nelson
20575 posts in 715 days
366 days ago
Yes it is the same stuff but mineral spirits is not a finish. You can apply it to wood to simulate what a clear topcoat will look like but it will simply evaporate in just a few minutes and leave nothing behind.
View trifern's profile
trifern
7894 posts in 660 days
366 days ago
Mineral spirits is a solvent, mineral oil can be used for a finish.
View Joey's profile
Joey
259 posts in 708 days
365 days ago
you can add minieral spirits to thicker finishes like polyurethane, BLO, or 100%pure tung oil to thin it so that it is easier to wipe on and to also help it cure faster. If you do it this way it won’t build as fast, so it takes more coats. I’ve found that it has less of a plastic look.
-- Joey, Magee, Ms http://woodnwaresms.com
