A puzzler
« back to Joinery forum
Forum topic by RussellAP posted 09-18-2013 06:29 PM 965 views 0 times favorited 12 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3103 posts in 2191 days
09-18-2013 06:29 PM
I have some one inch sticks from the same tree as this slab that I’m working on for my mother in law. My father in law commissioned it done, but he’s dead now so she want’s me to complete it.
I’m wondering how to attach legs from aprox one inch branches to the under side of this slab in four places.
Any idea’s?
12 replies so far
View pintodeluxe's profile
pintodeluxe
5566 posts in 2718 days
#1 posted 09-18-2013 06:56 PM
You could drill holes with a forstner bit. Perhaps use a tenon cutter to cut tenons on the branches. Otherwise, they could be turned to fit.
You might come up with a drilling guide to keep the holes at the same angle.
Good luck with it.
View lumberjoe's profile
lumberjoe
2894 posts in 2153 days
#2 posted 09-18-2013 07:23 PM
How heavy is that slab?
View Wildwood's profile
Wildwood
2240 posts in 2039 days
#3 posted 09-18-2013 08:29 PM
I would be tempted to make an angled skirt on bottom of tablle top to attach legs and add box stretcher near bottom of legs.
If want to drill angled holes in table bottom for legs would still put box stretcher near bottom of legs.
-- Bill
RussellAP
#4 posted 09-18-2013 11:30 PM
Lumberjoe, the slab is 40 years old and very dry, I’d say it’s only about 25lbs if that much.
Here are the sticks I have to work with for the legs.
RussellAP
#5 posted 09-18-2013 11:31 PM
pintodeluxe, I don’t know how I’d get the leg to fit a hole. if I could turn the leg I could put a tenon on it, but there has to be an easier way.
RussellAP
#6 posted 09-18-2013 11:35 PM
Wildwood, I don’t think a box stretcher would work for the sticks I’m using.
View redSLED's profile
redSLED
790 posts in 1797 days
#7 posted 09-19-2013 01:18 AM
Stick leg ideas for you . . .
Wildwood
#8 posted 09-19-2013 12:09 PM
Russell if had seen that pile of sticks would not have wasted my time responding to your post.
I would lie to mother-in-law saying I broke too many sticks trying to build set of legs. Then simply turn legs & stretchers from stronger wood.
-- Bill
lumberjoe
#9 posted 09-19-2013 04:55 PM
You don’t need to turn them, look for a tenon cutter.
Like Bill said, that pile of sticks isn’t even firewood. Those would go out on Wednesday in lawn and leaf bags. Without stretchers or some kind of apron, it would rack itself over in a gentle breeze.
View Dallas's profile
Dallas
3599 posts in 2392 days
#10 posted 09-19-2013 05:32 PM
Use a hole saw of appropriate size to make the tenon you want. Use a forstner bit of appropriate size to make the mortice.
try to make the tenon just a bit larger than the mortice. Force and cut, force and cut.. you’ll soon have a good fit.
RussellAP
#11 posted 09-19-2013 07:25 PM
I worked with another concept today and I like it.
Small legs, with some style made from solid cherry.
What do you think?
Wildwood
#12 posted 09-19-2013 07:54 PM
I like it, would like it more with stretchers. You really needed more especially thicker sticks to work with.
-- Bill
