What can I use over Howard's as a sealer?
Forum topic by Jeffreaux2 posted 09-18-2013 02:16 PM 1036 views 0 times favorited 8 replies Add to Favorites Watch
View Jeffreaux2's profile
Jeffreaux2
17 posts in 1855 days
09-18-2013 02:16 PM
I am finishing up a Nantucket Bench constructed of Sinker Cypress. I have already wiped in a dose or two of the Howard’s Feeed N Wax. Is there a satin finish I can seal it with?
Shellac? Poly? Or…...?
-- Regards, Jeff
8 replies so far
View pintodeluxe's profile
pintodeluxe
5722 posts in 2863 days
#1 posted 09-18-2013 07:02 PM
Sealer or topcoat needs to be applied before any wax product. If you seal it now, the finish won’t adhere properly.
View Bill White's profile (online now)
Bill White
4977 posts in 4010 days
#2 posted 09-18-2013 08:10 PM
Might wanna wipe down real well with naphtha, add a coat of dewaxed shellac (Seal Coat), buff with a non-woven pad, then apply your top coat of choice.
Interior or exterior use?
Bill
-- bill@magraphics.us
View Clint Searl's profile
Clint Searl
1533 posts in 2411 days
#3 posted 09-18-2013 08:57 PM
You already blew it. Just smear more wax over it, and be done.
View gfadvm's profile
gfadvm
14940 posts in 2740 days
#4 posted 09-19-2013 01:20 AM
I have put shellac over mineral oil/wax mixture and much to my surprise it worked perfectly! I did nothing to remove the MO/wax before applying the shellac.Click for details
View tefinn's profile
tefinn
1222 posts in 2487 days
#5 posted 09-19-2013 01:38 AM
You might get away with just shellac like gfadvm, but I’d do as Bill says. You’ll have a better chance of getting good adhesion after a thorough wipe down with naptha. If you’re going to use the shellac as the top coat, it doesn’t have to be dewaxed.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
Jeffreaux2
#6 posted 09-19-2013 02:58 AM
I put a couple coats of Danish oil on it. I’m going to see what is looks like in a day or two. I am considering a sanding sealer and then breewax.
-- Regards, Jeff
tefinn
#7 posted 09-19-2013 03:26 AM
You just made it worse. Nothing, except for maybe the shellac that was suggested, will adhere to the wax you put on the wood. The Danish oil may dry if your lucky, but it will eventually fail.
View Finisherman's profile
Finisherman
227 posts in 1899 days
#8 posted 09-20-2013 05:33 PM
At this point, I think that your best bet might be to strip the finish and start over. If that’s not an option, and assuming that the Danish oil dries properly, apply several coats of dewaxed shellac after allowing the Danish oil to cure thoroughly. Don’t try to apply lacquer, varnish, poly or waterborne finish over the Howard’s. You’ll be asking for trouble if you do. Having said that, you might get away with applying lacquer over the dewaxed shellac, but I don’t know if I’d want to take that risk.
