Dust collector fittings question
Forum topic by JimNEB posted 09-18-2013 03:26 AM 820 views 0 times favorited 3 replies Add to Favorites Watch
View JimNEB's profile
JimNEB
239 posts in 3037 days
09-18-2013 03:26 AM
Topic tags/keywords: dust collection question
I’ve looked at every thing I can find on fittings (now my wife says I don’t do a very good job of looking for stuff.) I want to connect a gate right to the outlet on my table saw or else right at the wye going into my dust collector. Problem is thy ate both the same OD :(. I figured there would be a fitting that would fit over each and bada-bing it would be done. Easy peasy japanese…but I can’t find any thing like that, the best my feeble brain can come up with is to cut a short piece of hose and connect to each, not very elegant.
-- Jim, Nebraska
3 replies so far
View rum's profile
rum
148 posts in 2555 days
#1 posted 09-18-2013 06:08 AM
You don’t say what size it is – assuming 4”?
I’ve had pretty good luck just taking parts and pieces down to the local hardware stores and junk yards looking for possibly matching parts (my setups all look kinda rube goldberg but they mostly work pretty well).
In this case you’re looking for something you can use as a sleeve.
You might find a piece of stove pipe that would fit or perhaps a rubber clamp-on sewer pipe fitting would work.
If its a little loose get some of the “duct sealant” from the hardware store and goop it on there. It goes on globby and dries hard (but not so hard you can’t break the join later if you need to).
4956 posts in 2462 days
#2 posted 09-18-2013 11:17 AM
Get a short piece of 4” PVC (thinwall, astm 2729), say 5-6” long. Cut a slit down the side (you may have to cut out a small 1/2” or so section) then wrap it around the 2 fitting, put SS clamps on each end, tape the split.
View rrww's profile
rrww
263 posts in 2082 days
#3 posted 09-18-2013 11:38 AM
I would look for a rubber sewer fitting with hose clamps on both ends.
