Need a better way to hinge top
Forum topic by boroughdan posted 09-18-2013 01:52 AM 1085 views 0 times favorited 10 replies Add to Favorites Watch
View boroughdan's profile
boroughdan
22 posts in 1911 days
09-18-2013 01:52 AM
This is a 36”x18” box that will hold a litter box. The top is 3/4” pine I was going to put 4 hinges on the back to hold it on, in mounting it that way when opened it goes a few degrees past vertical. i tested this on some boards with similar dimensions but with more weight. I was a little rough with it but the hinges failed. They just werent thick enough to hold the weight so they were bending above the screw holes. Can you point me to something i can use to hold that top up/keep it from going past vertical so it doesnt stress the hinge…or another idea. Unfortunately i goofed up and the top is only about 1” wider than the box so i have to use small hinges.
10 replies so far
View bondogaposis's profile (online now)
bondogaposis
4690 posts in 2321 days
#1 posted 09-18-2013 01:53 AM
Picture?
-- Bondo Gaposis
View firefighterontheside's profile (online now)
17976 posts in 1826 days
#2 posted 09-18-2013 02:11 AM
How about using some type of cabinet hinges as if you were mounting a door on a cabinet. Possibly European style or half inch overlay hinges.
http://www.amazon.com/Amerock-BP7550-ORB-Self-Closing-Partial-Overlay/dp/B000I22LUM/ref=sr_1_5?ie=UTF8&qid=1379470033&sr=8-5&keywords=Overlay+hinges
boroughdan
#3 posted 09-18-2013 02:27 AM
Can you tell me why that would be stronger than what ive tested. Not sure what the ones i have are called. I know “normal” isnt right but the kind that are on a door.
#4 posted 09-18-2013 02:50 AM
Did your hinges fail when you opened it up all the way and then the weight of the lid pulled the screws out? You said the top is one inch bigger than the box so 1/2 on each side. That makes for a lot of leverage when it opens all the way. If the top was the same size as the box, you could mount the hinges so that the top opens all the way, assuming the box is at least as tall as it is wide. This way the hinges would not be stressed.
View Gary's profile
Gary
9328 posts in 3402 days
#5 posted 09-18-2013 02:54 AM
Put a chain on it to take the strain off of the hinges
View bigblockyeti's profile
bigblockyeti
5106 posts in 1690 days
#6 posted 09-18-2013 01:29 PM
For tops like what you’re describing, I’ve had good luck with using piano hinges, they have screws every 3” or so and given that they will fit into a recess usually cut into the top of one side for a top that you want to stop a little past vertical or into the side of one side for a top that you want to open 180 degrees. cutting the recess into the top, I’ll usually cut the bottom of the recess down slowly to get the swing I’m looking for.
bigblockyeti
#7 posted 09-18-2013 01:30 PM
Another option would be to use a chain, or hydraulic strut to limit the swing of the top to where you want it.
bondogaposis
#8 posted 09-18-2013 01:37 PM
Another vote for piano hinge and a strut to support the lid when open.
-- Bondo Gaposis
View BJODay's profile
BJODay
526 posts in 1912 days
#9 posted 09-18-2013 01:47 PM
Used a piano hinge and a pair of lid supports from Rockler. It holds the lid up well, but the supports keep it from opening all the way past 90.
BJ
boroughdan
#10 posted 09-18-2013 01:47 PM
The strut sounds better than a chain. I know a chain would solve the problem but i dont think i would like the look. So with a strut i could set a max opening? Ideal would be if it could open just past vertical so it would stay open but not so far it stresses the hinges.
