Wood bit lubricant?
Forum topic by bwanamdogo posted 09-17-2013 12:37 PM 1141 views 0 times favorited 8 replies Add to Favorites Watch
View bwanamdogo's profile
bwanamdogo
15 posts in 1678 days
09-17-2013 12:37 PM
Topic tags/keywords: wood bit lubricant
I am making a series of Roorkhee chairs from hard maple which use a conical mortise hole which I am cutting with a three-flute reamer in a milling machine. The reamer cuts just fine but produces a high-pitch scream, even at low rpm. I am curious as to whether anyone has found a lubricant which might reduce that noise and yet not interfere with the final application of a finish.
-- Bwanamdogo
8 replies so far
4827 posts in 2365 days
#1 posted 09-17-2013 12:50 PM
With no idea whether this would work, you might try beeswax. I use it as a wood screw lubricant in hardwoods, and haven’t had any problem with the finish. Might be worth giving a test drive.
View Rick_M's profile
Rick_M
10817 posts in 2252 days
#2 posted 09-21-2013 03:30 AM
I’ve tried oil and wax to some benefit but it doesn’t stop the squeaking entirely. When drilling on the lathe I wear ear muffs.
-- http://thewoodknack.blogspot.com/
View vipond33's profile
vipond33
1405 posts in 2369 days
#3 posted 09-21-2013 04:11 PM
Bostik DriCote would probably work for you.
-- gene@toronto.ontario.canada : dovetail free since '53, critiques always welcome.
View Bill White's profile
Bill White
4820 posts in 3832 days
#4 posted 09-21-2013 07:01 PM
What speed are ya usin’?
Is there enough relief on the cutter?
Bill
-- bill@magraphics.us
bwanamdogo
#5 posted 09-21-2013 08:06 PM
Bill, I am using a vertical milling machine, turning about 350 rpm. The three flute spiral and tapered reamer is hollow ground but with an 1/8 inch flat trailing the cutting edge by about 3/16 inch. I don’t know to how many thousands the flat is relieved from the cutting edge but have assumed that the trailing flat is the noisemaker. Ken
-- Bwanamdogo
View HorizontalMike's profile
HorizontalMike
7727 posts in 2785 days
#6 posted 09-21-2013 09:17 PM
+10 Bostik Drikote
bwanamdogo
#7 posted 09-21-2013 09:39 PM
Thanks to all those who have responded. Looks like Drikote might be the solution.
-- Bwanamdogo
HorizontalMike
#8 posted 09-22-2013 12:35 AM
BTW, this really helps when you have to use a template with a hand drill for drilling large holes, such as 3/4in dog holes, It really saves the day.
Quite literally, I would spray the bit ever other hole and things went at least twice as fast or more. I could have sprayed every time but I was being conservative. Later on, I realized that that would have actually saved me additional time and effort. I balked at the ~$20 cost at WC, but later found better deals online and for 3-paks and such. Well worth the effort to look for deals, IMO.
Do note that the can has changed it’s looks.
