Help
Forum topic by Insagent posted 09-17-2013 03:15 AM 841 views 0 times favorited 5 replies Add to Favorites Watch
View Insagent's profile
Insagent
51 posts in 2334 days
09-17-2013 03:15 AM
What would be the best way to plain several thick slabs of oak and walnut? They are about 30 inches wide and 4 inches thick. I have 15 inch plainer so any suggestions?
5 replies so far
View bigblockyeti's profile
bigblockyeti
5137 posts in 1744 days
#1 posted 09-17-2013 03:18 AM
30” wide is gonna be a tough one. If they’re fairly dimensioned already, you might call around to see if someone in your area might have a wide belt or drum sander. While neither will plow off wood like a planer will, the finish will be great.
View RBWoodworker's profile
RBWoodworker
441 posts in 3375 days
#2 posted 09-17-2013 03:15 PM
I second bigblockyeti.. it’s the best way to do it..
-- Randall Child http://www.racfurniture.com/
View natenaaron's profile
natenaaron
442 posts in 1820 days
#3 posted 09-17-2013 03:41 PM
You can use a router in a sled jig. That is my plan. Fine woodworking had a plan in their website somewhere, wood whisperer has a video about it, and there are a couple other youtube videos available showing how it works. Seems easy enough.
I have not tried it yet so cannot speak from experience. I built the sled and it was easy.
Edit:
I found the Fine woodworking link
http://www.finewoodworking.com/how-to/article/level-big-slabs-in-no-time-flat.aspx
View Nomad62's profile
Nomad62
726 posts in 2981 days
#4 posted 09-17-2013 04:13 PM
A drum sanding job on several slabs will cost a small fortune if they are warped at all, I highly recommend the router/sled combination. It is kind of difficult to get it just right, but at least a person can get it close to help defray the cost of sanding. A plane,well used, will work well as well.
View rrww's profile
rrww
263 posts in 2136 days
#5 posted 09-17-2013 05:57 PM
Router sled one side to get it square then take it to someone with a widebelt to have a perfect slab. Drum sanding somthing like this would be crazy expensive.
Or cut the slabs in half and re-glue.
