Does Shellac interfere with glue?
« back to Joinery forum
Forum topic by mummykicks posted 09-16-2013 02:48 PM 1141 views 0 times favorited 2 replies Add to Favorites Watch
View mummykicks's profile
109 posts in 1736 days
09-16-2013 02:48 PM
I was pondering this while trying to decide if I should seal the inside of a hollow art table top I’m making, or any other box I end up making. So I decided to do a little experiment.
One coat of shellac on a some plywood, and one coat on the edges of the ribs I was going to glue, one plywood, one mdf.
Some titebond and a couple pocket screws to provide the clamping:
Let it cure overnight at 80 something degrees. Removed screws and tried to break it apart by hand, no dice. Got my deadblow hammer and gave it a good whack and it came apart:
I think it’s safe to say it doesn’t, at least one coat doesn’t. If I left the screws in there I don’t think that joint is ever coming apart.
Anyway, I just thought I’d post it on the remote chance someone else ever wonders about this as well…
2 replies so far
117032 posts in 3511 days
#1 posted 09-16-2013 03:24 PM
Good idea to conduct a test.You test answers your question. In most cases I would say mask of where your going to glue up .
-- wood crafting & classes
View Jim Jakosh's profile
Jim Jakosh
20169 posts in 3039 days
#2 posted 09-24-2013 11:37 PM
I would avoid any sealer on the wood where the glue is expected to be holding. It needs bare wood to bite in. It will hold to a degree because of it’s nature, but not like raw wood!...........Jim
