Mortising quest.
Forum topic by Mark posted 09-15-2013 05:33 PM 1045 views 0 times favorited 4 replies Add to Favorites Watch
View Mark's profile
Mark
984 posts in 2214 days
09-15-2013 05:33 PM
Morning all. I’m making a couple of foot stools Mission style. I usually use false tenons on the front of the legs to give the piece a through tenon look. This time I’m trying real through tenons. I have the leg set up on a drill press with a 3/8 brad point bit. I put a piece of scrap under the leg to prevent tear out from the bit. I drill holes as close together as I can, then clean out the waste with a chisel, but I still can’t get a clean straight cut. The tenons are tight in the mortise but I don’t have a clean tight fit on the front. There’s some times a bit of splitting. Any thoughts?
Thank you. Mark
-- Mark
View waho6o9's profile
waho6o9
8539 posts in 2816 days
#1 posted 09-15-2013 05:49 PM
Rasp maybe? I was amazed on how one swipe of the
fine rasp would make the joinery fit well.
HTH
View Loren's profile
10477 posts in 3887 days
#2 posted 09-15-2013 07:22 PM
It’s easier to make them appear to fit tight by using
wedges. The mortise is actually tapered a bit too,
but you can wedge without the taper too.
In terms of making a clean mortise with parallel sides
using a drill and chisel, carefully mark out the mortise
on both sides, drill undersized holes and pare carefully.
You can do it, just do carefully.
I find it easier to make such a mortise using a plunge
router to make a stopped mortise, flipping the work
over and using a pattern-trimming bit to cut though
from the other side.
View DrTebi's profile
DrTebi
267 posts in 3506 days
#3 posted 10-15-2013 06:52 AM
If your mortise doesn’t end up straight, maybe the drilled holes were not drilled straight in the first place? It’s just an idea, something to check.
I use a very simple method to level my drill press table, it only requires a steel rod, even a metal cloth-hanger works. It’s described here:
http://www.woodworkerblog.com/checking-drill-press-table-alignment/
Again, it’s just a thought.
View paratrooper34's profile
paratrooper34
915 posts in 3191 days
#4 posted 10-15-2013 01:13 PM
Mark, I see your post is a month old, so if you haven’t figured this out yet, here is my two cents. Since you are doing mission type furniture, I will assume you are using white oak? Using a brad point bit is probably the issue. Even a 3/8” bit can wander in the grain in white oak and give degraded results. I suggest you use a forstner type bit to hog out waste in a mortise as the bit will keep very stable while drilling. Good luck.
-- Mike
