Drill Press - Mortiser retrofit
Forum topic by pashley posted 372 days ago 276 views 0 times favorited 9 replies Add to Favorites Watch
View pashley's profile
pashley
530 posts in 615 days
372 days ago
Topic tags/keywords: mortise
I’ve seen kits to turn drill presses into mortise machines. Has anyone used them, and if so, your experience?
-- http://newmissionworkshop.com
View lew's profile
lew
4497 posts in 653 days
372 days ago
There was a post here a few days ago in this topic. If I remember correctly, most favored a dedicated setup. I had one but I eventually replace it with the dedicated type. It took time to setup. It would slip on the quill when I applied downward pressure- no matter how tight I made it. Now I am not much of a planner, but no matter how well I thought out everything, I always needed the drill press before I finished the mortises.
View Icemizer's profile
Icemizer
68 posts in 437 days
372 days ago
Had one but in the end it was more trouble than it was worth. Bought a dedicated mortiser and am much happier with the operation.
-- Say what you mean and mean what you say.
View northwoodsman's profile
northwoodsman
100 posts in 644 days
372 days ago
I wouldn’t waste the money on the attachment. I have one that came with my Jet drill press and I used it once and it cracked right away. Jet sent me another one and I used it for a couple of mortises. It really puts a lot of stress on your drill press components. It’s easier to drill holes with your drill press then clean them up with a chisel.
-- NorthWoodsMan
View christopheralan's profile
christopheralan
241 posts in 618 days
372 days ago
View Bill White's profile
Bill White
111 posts in 858 days
368 days ago
I have one. Wanna buy it?
Bill
View doyoulikegumwood's profile
doyoulikegumwood
278 posts in 890 days
368 days ago
i also have one and i wont sell it to you im not that meen
ps even this mortiser would be a better investment http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=35570
-- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more
View ChicoWoodnut's profile
ChicoWoodnut
895 posts in 713 days
368 days ago
I have to join the rest of the voices here. I had the Delta years ago and it was a pain in the butt. I takes a long time to set up and get centered. Not only that but it will eventually ruin your drill press. Most of the drill presses woodworkers use are cheap and light duty. They just aren’t made to produce the force necessary to push a square chisel through hard wood. As soon as I started noticing my drill press was getting sloppy I went out and bought a dedicated machine. I never looked back.
Remember, there are a lot of ways to make motises including drill bits and routers. I just like the fact that the dedicated machine is always sitting there begging to make mortises at a moments notice.
ChicoWoodnut
368 days ago
Yikes!
I just looked at that HF mortiser. I think the force of the downstroke would turn that puny rack post into a noodle in no time.
doyoulikegumwood
368 days ago
yes chico but its still a better invesment lol
