How do I take apart this Millers Falls block plane?
« back to Hand Tools forum
Forum topic by ColonelTravis posted 09-14-2013 09:49 PM 2550 views 0 times favorited 17 replies Add to Favorites Watch
View ColonelTravis's profile
ColonelTravis
1769 posts in 1891 days
09-14-2013 09:49 PM
Topic tags/keywords: block plane restore millers falls
Tiny screw on the side is not cooperating.
Need to avoid stripping it, what’s the best way to get this out? As for the rest, it seems to be fairly straightforward. There’s a little pin I need to tap out on the back, otherwise I guess that’s it? So many how-to’s all over the place with bench planes, very little about the smaller ones. I’ll post one of this one, just really want to be careful with that screw. I’ve got lots of mini screwdriver heads and I obviously want the widest one that fits, but none are doing the job.
Also – the wood knob just screws on the front, and when I took that off some of the wood inside crumbled out. It’s still threaded inside, and I didn’t put it back on because I didn’t want to keep putting it on and taking it off and risk ruining the threads. Is there a way to strengthen the inside of the knob?
17 replies so far
View Don W's profile
Don W
18713 posts in 2565 days
#1 posted 09-14-2013 09:59 PM
Can you take a picture from the top? That looks like a 103 knock off which mean the cap should be under a bar. I’ve never seen a plane that style where the side screw did anything. If you completely loosen the cap, it slide from under the bar.
As for the knob, it depends how bad it is. Some wood stabilizer may work. You can also wax the threads really well and add some epoxy. The wax will prevent the epoxy from sticking to the metal and form a new set in the wood.
View dhazelton's profile
dhazelton
2767 posts in 2294 days
#2 posted 09-14-2013 10:00 PM
Do you have a cordless impact driver? I’ve had success with one trying to get stubborn screws out where a hand screwdriver would just destroy the head.
View JustJoe's profile
JustJoe
1554 posts in 2036 days
#3 posted 09-14-2013 10:13 PM
Put down the impact driver and back away from the plane.
Like Don said, that “screw” on the side is not there to help you disasemble. You just need to move that wheel underneath the lever cap. Look at it from the side and you’ll see which way the threads go on that bolt it it sitting on. Turn it until it is loose. If you can’t turn it by hands then channel-locks with a gentle-touch and some tape over the jaws will get it started. Once you loosen that up the lever-cap will just slide out the back.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
ColonelTravis
#4 posted 09-14-2013 10:13 PM
For reference, this is equivalent to a Stanley 120.
ColonelTravis
#5 posted 09-14-2013 10:21 PM
JJ – success!
As for the knob – is there a way to make the inside threads more stable? Wood filler? Glue? Something else?
This site is invaluable. Thanks.
View GlenintheNorth's profile
GlenintheNorth
244 posts in 534 days
#6 posted 01-15-2017 08:58 PM
You know…I realize I’m necroposting, but that is a very, very early type 1 #97. That plane was probably made in 1929, in the first year they were released. The red caps were quickly replaced with black.
I also have a type 1 #97, but my cap is black. I hope you haven’t repainted it!
-- MFia-made man. But that doesn't mean I don't dig my 45. Minneapolis/St. Paul, burbs.
ColonelTravis
#7 posted 01-15-2017 09:03 PM
Long ago repainted and sitting on my bookshelf, only plane I’ve ever bought for non-use. It is what it is. But I appreciate the info.
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3112 days
#8 posted 01-15-2017 09:09 PM
great to see both the before and after shot :)
congrat with the fine result
and thanks for sharing :)
Dennis
GlenintheNorth
#9 posted 01-15-2017 11:17 PM
It looks great! :)
ColonelTravis
#10 posted 01-15-2017 11:30 PM
Thanks. This DupliColor engine paint, which is really popular to use in black for Stanley restores, ended up being pretty much a perfect match for Millers Falls red. I also used it for the lever cap lettering in my MF #9.
The underneath side is original, top is what I painted.
GlenintheNorth
#11 posted 01-15-2017 11:46 PM
That is really interesting…
I have been a little worried about the tint of the red paints on the market. I have a type 1 #9 coming that has already has some repaint done to it. I want to strip and recoat. That red looks very close.
ColonelTravis
#12 posted 01-16-2017 12:16 AM
Sorry, I also did the frog on my 9 with that paint. I haven’t compared it to an original untouched 9. It’s kind of hard to gauge from just a photograph, but originally when I compared the underside of that block plane cap to the engine paint I honestly could not tell a difference. I left the underside as it was, no retouching. And just a minute ago I took another look, got the cap off and still could not tell a difference. To me it’s a great match.
Don W
#13 posted 01-16-2017 01:12 AM
It does look good!
View HokieKen's profile
HokieKen
4996 posts in 1136 days
#14 posted 01-16-2017 11:19 AM
That’s the same paint I used on my MF9. It’s a nearly perfect match.
-- Kenny, SW VA, Go Hokies!!!
GlenintheNorth
#15 posted 01-16-2017 12:22 PM
I might have to send you some frogs for blasting, Don. I’m not allowed to do them at work! Something about contamination and the FDA or something…
