Is there a recommended cleat angle for hanging a shop cabinet?
Forum topic by laketrout36 posted 09-14-2013 01:03 PM 2341 views 0 times favorited 14 replies Add to Favorites Watch
View laketrout36's profile
laketrout36
200 posts in 2232 days
09-14-2013 01:03 PM
Topic tags/keywords: cabinet cleat jig hanging hang shop storage
The shop is in need of a hanging cabinet and I’d like to use a cleat system to hang it and possible another on. I’m wondering is there a recommended angle for the wall cleat? Does a shallower angle give greater or lesser of a secure fit? I have a small shop and would like to have longer cleats that I could hang a variety of future items on when not in use. Mainly it would be to hand a shop cabinet on. What are your ideas? What would you do over? Thanks for any and all ideas.
14 replies so far
View mtenterprises's profile
mtenterprises
933 posts in 2898 days
#1 posted 09-14-2013 01:23 PM
I have always just used a 45 deg. when I have used french cleats but who knows maybe there is a “Correct Angle”.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View Gene Howe's profile
Gene Howe
11079 posts in 3634 days
#2 posted 09-14-2013 01:35 PM
I go a bit steeper than 45. But, I doubt, it makes a huge difference.
13640 posts in 3546 days
#3 posted 09-14-2013 01:38 PM
i would think anything from 30 or more would be OK
as the pull is mostly ‘down’
locking them together
if the cab is really deep
45
might be better
as some pull ‘out’ might be involved there
View jap's profile
jap
1251 posts in 2259 days
#4 posted 09-14-2013 01:42 PM
I dont use cleats, but Keep I mind that the steeper the angle the more the cleat acts as a wedge pulling the cleat out of the wall. A lesser angle pulls the cleat down. 45 is probably a happy medium.
-- Joel
View cagenuts's profile
cagenuts
36 posts in 2426 days
#5 posted 09-14-2013 01:44 PM
45 without a doubt, anything less and you risk breaking off the cleat and anything more may not lock properly.
It’s also dead easy to rip 45.
-- Weekend Wood Wrecker
View NiteWalker's profile
NiteWalker
2738 posts in 2782 days
#6 posted 09-14-2013 02:03 PM
45. No reason to choose anything else as I’ve never heard of a 45 failing, nor has it failed for me.
View knotscott's profile
knotscott
8154 posts in 3581 days
#7 posted 09-14-2013 02:57 PM
45° sure is convenient.
View bondogaposis's profile
bondogaposis
5098 posts in 2557 days
#8 posted 09-14-2013 03:32 PM
I use 45°.
-- Bondo Gaposis
View WayneC's profile
WayneC
13794 posts in 4303 days
#9 posted 09-14-2013 03:33 PM
45 as well….
laketrout36
#10 posted 09-15-2013 01:27 PM
Thanks everyone.
View NoLongerHere's profile
NoLongerHere
893 posts in 2881 days
#11 posted 09-15-2013 05:54 PM
Thanks for any and all ideas.”
Why not screw it directly to the wall?
Are you planning on moving the upper cabinets around the room several times a year? Maybe I’m missing something and it works best in your application, like a cabinet display at a convention.
But, It takes more work and wood to use a cleat system. It forces the cabinets out 3/4” and leaves a gap on the side unless you fill it. Kitchen cabinet installers don’t use them 99.9%....right?
Just screw it to the wall. It’s much stronger. If you move it for some reason, screw it to the wall again.
Cleats suck as hangers for anything else. Speaking in general, I just don’t get this love affair with cleats.
but, like I said, maybe it works best in your case.
View MrRon's profile
MrRon
5203 posts in 3449 days
#12 posted 09-15-2013 07:08 PM
Mark, I used to screw cabinets to the wall, but now that I am in my 70’s, cleats allow me to save my back. It just makes it easier to hang. In fact, I can install the cleats and let the kids hang the cabinets. I did this recently for a laundry room for my daughter.
View BHolcombe's profile
BHolcombe
180 posts in 2281 days
#13 posted 09-15-2013 07:14 PM
I just built a set of wall hung bookcases and used 30 degrees. I used a cleat because it allowed me to spread the load evenly over more studs than if I had screwed it directly to the wall.
Also, much easier for me to position a 75lb bookcase on the wall with a cleat.
View BArnold's profile
BArnold
175 posts in 2038 days
#14 posted 09-15-2013 07:55 PM
I’ve hung all of my cabinets on cleats using a 45° angle. I’ve read others say they use 15° with no issue. So, from that bit of evidence, it would appear that any angle from 15° to 45° will work. Just don’t try to go more than 45°, OK??? :)
-- Bill, Thomasville, GA
