Replaceable Cutter Heads for Turning...
« back to Woodturning forum
Forum topic by ScrubPlane posted 09-14-2013 12:28 AM 1394 views 0 times favorited 6 replies Add to Favorites Watch
View ScrubPlane's profile
190 posts in 2124 days
09-14-2013 12:28 AM
Topic tags/keywords: tip question lathe turning
I utilize the ‘Easy Wood Tool’ turning tools and like them very much. One thing I would like, however, is a cutter that has a slight ‘inward’ facing radius (the opposite of the ‘outward’ radius one sold by Easy Wood).
Do any of you know of a brand of a cutting tool that fits this description? I’ve had no success in my surfing for one and am doubting its existence at this time…just thought I’d ask the fellow turners.
Thank you…
View lew's profile
11982 posts in 3684 days
#1 posted 09-15-2013 12:14 AM
You might check with this guy- Capt. Eddie
View Nubsnstubs's profile
1265 posts in 1659 days
#2 posted 09-15-2013 03:19 AM
Scrub, I don’t think you’ll find anything like that in carbide, specifically fitting Easy Wood Tools. You could try Carbide Depot, and from there you should find other links to chase. You could also call EWT and ask if they can do a specieal grind. .......... Jerry (in Tucson)
-- Jerry (in Tucson)
View Ron Ford's profile
Ron Ford
206 posts in 1661 days
#3 posted 09-16-2013 02:42 AM
I agree with Lew and recommend calling Cap’n Eddie (Castelin) for your replacement cutter heads. One thing I found on the Easy Finisher (round) tips I got from him is that they are a bit thinner than the original that came with the EWT. Also, the screws he supplies with his did not fit my EWT chisel. No problem on either issue – I just reused the original screw that came with the tool, and put a #10 washer under the new tip. They are super sharp and WAY less expensive than the ‘store brand’.
-- Once in awhile I make something really great. Most days I just make sawdust.
View Woodknack's profile
11285 posts in 2309 days
#4 posted 09-16-2013 02:56 AM
There is a guy on ebay who sells EWT carbides (the actual ones) for cheaper than I’ve seen anywhere else but I no longer have him bookmarked. They are still more expensive than Capn Eddie but a good deal if you want the exact same cutters.
-- Rick M,
View SteveKnnn's profile
66 posts in 1817 days
#5 posted 09-16-2013 03:03 AM
ScrubLane, I have to ask, why do you want the reverse curve? What improvement over the square cutter would it give you?
-- Steve in Richmond, VA
View Don Thur's profile
Don Thur
9 posts in 2188 days
#6 posted 01-27-2014 12:34 AM has excellent quality nanograde cutters at a very reasonable cost.
I am the seller and a professional turner.
-- Don
