lathe
« back to Woodturning forum
Forum topic by kiik posted 09-13-2013 08:18 AM 1577 views 0 times favorited 15 replies Add to Favorites Watch
View kiik's profile
kiik
6 posts in 1954 days
09-13-2013 08:18 AM
can someone tell me the mt for a live center for a craftsman10323180 lathe
15 replies so far
View Knothead62's profile
Knothead62
2600 posts in 3198 days
#1 posted 09-13-2013 10:47 AM
Contact Sears or do a search for that model number. Or, you could borrow something with a #2 MT and see if it fits.
Edit: I did a search and it is a #1 MT. Some accessories in that size are hard to get or nonexistent. #2 MT is pretty much the standard. I almost bought a lathe at a great sale price but passed it up as it was a #1 MT.
View kiik's profile
kiik
#2 posted 09-13-2013 02:19 PM
I have done some research and that is what I came up with. Thank you for the reply!
View Woodknack's profile
Woodknack
12464 posts in 2617 days
#3 posted 09-24-2013 03:14 AM
I’m late to the party but a good source for 1MT live centers and drill arbors is Littlemachineshop.com. Highland hardware is the cheapest source for 1MT spur centers. Work arbors can be found on ebay. And every Sears lathe ever was 3/4”x16 threads with 1MT and they made a buckton of lathes so accessories are not difficult to find.
View Jim Jakosh's profile
Jim Jakosh
21961 posts in 3342 days
#4 posted 10-01-2013 03:20 AM
You don’t need to go to Sears for a MT live center. Measure the hole in the tailstock arbor at the outer end of the taper. If it is about .680” it is a Morse #2. If it is about .460” it is a Morse#1. With that knowledge, you can order one from Grizzly or on E bay. I personally like to use a live center for a metal lathe on my wood lathe because it is slimmer and I can get closer to the piece when finishing off the bottom .
Cheers, Jim
PS.
I have 2 Craftsman 15” x38” lathes and they have a 1”-8 threaded spindle and the head and tails stocks are both #2 tapers
Jim Jakosh
#5 posted 10-01-2013 03:25 AM
Here is the book on it:
http://vintagemachinery.org/pubs/detail.aspx?id=856
This book says it is a dead center (p/n24104 and no longer available) but it looks awful small. If you send me a picture and some measurements, I may be able to tell you what you have. My e mail is jcj7815@att.net.
thanks, Jim
Woodknack
#6 posted 10-01-2013 05:47 AM
He has 1MT Morse tapers and a 3/4×16 spindle; backside of the headstock is 3/4×16 LH.
Bearings are 3/4in x 40mm x 12mm (mixed standard/metric), look for 6203-3/4 ZZ.
View kiik's profile
kiik
#7 posted 10-01-2013 09:51 AM
the headstock spindle on my 10323180 craftsman lathe is round with a flat it is a 1mt. I am thinking there must be an adapter to mount a faceplate but i can’t seem to find one. I Inherited this lathe and am hoping that I can use it to turn bowls
thanks kiik
Woodknack
#8 posted 10-01-2013 01:12 PM
You must have the first year version without threaded spindle which was Sear’s stupidest idea of all time. You will not be able to turn bowls without replacing the spindle with one from a later model. It might be possible to modify a faceplate to work. I don’t know if Sears ever made faceplates to fit that lathe.
View kiik's profile
kiik
#9 posted 10-02-2013 02:18 AM
you would think all you have to do is find a 1mt with a 3/4×16 tpi end. I am complete novice, so I don’t know if that would even work!!!??? Thanks for any help kiik
Woodknack
#10 posted 10-02-2013 04:10 AM
It would work. They make threaded arbors with tapers but all the 1MT ones I’ve seen are small like 3/8” or 1/4”. Doesn’t mean bigger ones don’t exist it’s just I’ve never had a reason to search for one.
Edit; bam!
http://www.ebay.com/itm/1-MT-Drill-Chuck-Arbor-3-4-x-16-Thread-/330937712373
Jim Jakosh
#11 posted 10-04-2013 01:25 AM
I could make you one with a #1MT and 1”-8 thread but it would not be hardened. I thought you at least had a thread on that spindle. I would use a #1 MT from a drill and weld it into a 1”-8 short thread or chase the thread on a blank piece to insure concentricity. Or I could cut the taper and chase the thread on 1 piece but that would be more expensive .
That way you could use standard 1’-8 accessories.
PM me if you want me to do either one of those!......Jim
I’d buy the one Rick showed: http://www.ebay.com/itm/1-MT-Drill-Chuck-Arbor-3-4-x-16-Thread-/330937712373
View JustJoe's profile
JustJoe
1554 posts in 2275 days
#12 posted 10-04-2013 01:30 AM
I’ve had and sold the Craftsman ones in the 3-5” range, so I know they exist – 3 jaw chuck with 1MT.
Here is a cheap HF version that is much smaller:
http://www.harborfreight.com/2-inch-mini-lathe-chuck-with-mt-1-shank-65132.html
It shouldn’t take too much ingenuity to hold a bowl blank with it, or take off the jaws and weld a generic face-plate to the front.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View kiik's profile
kiik
#13 posted 10-12-2013 11:10 PM
I have a chance to get a set of millers falls lathe chisels 8 total I am wondering what would be a good price? They are just like new
View Grandpa's profile
Grandpa
3261 posts in 2912 days
#14 posted 10-12-2013 11:18 PM
Penn State offers both #1 & #2 Morse tapers live centers in their latest catalogue. Cheap if you need one.
View TheDane's profile
TheDane
5575 posts in 3900 days
#15 posted 10-13-2013 01:35 AM
kiik—How much is the seller asking for them?
Are they HSS or carbon steel?
The original Millers Falls company has been out of business for over 30 years … Ingersoll Rand bought the Millers Falls Company in the 60’s, and in the early 80’s shut down the original operations. I don’t know if IR’s version of Millers Falls even made turning tools.
if these tools are in pristine condition, they might be worth something to collectors. If they are ‘users’, I would shoot them a low offer.
