How to smooth wood that has been re-sawn?
Forum topic by MrRon posted 09-12-2013 07:49 PM 1559 views 0 times favorited 24 replies Add to Favorites Watch
View MrRon's profile
MrRon
4634 posts in 3151 days
09-12-2013 07:49 PM
I resaw some wood on the bandsaw into strips that are 9/32” thick. Because of their rough surface, how do I get a finished 1/4” thickness. I don’t have a drum sander, but I do have a surface planer. I’m not sure if 9/32” is thick enough to get 1/4” finish using a planer. If I go with 5/16” resaw, it would probably work, but I may not get the number of slabs I need.
24 replies so far
View Woodbum's profile
Woodbum
802 posts in 2973 days
#1 posted 09-12-2013 08:00 PM
Mr. Ron:Better you than me running 9/32” strips through a planer. Look out for wood shrapnel. I personally would not do it, or would only do it with a carrier board with the strips double stick taped down to it. But even then, probably not. It’s one of those things that if your gut initially tells you NO WAY, then you probably need to go with your gut. That is just my opinion and I could be wrong.
-- "Now I'm just another old guy wearing funny clothes"
MrRon
#2 posted 09-12-2013 08:06 PM
I’m using pine. The strips are 1/4”x2-1/4”x12”.
View skyboy_psu's profile
skyboy_psu
21 posts in 1978 days
#3 posted 09-12-2013 08:30 PM
Look up Izzy Swan’s table-saw-into-jointer-sled. You can find this here or on youtube. It is just a table saw sled that will hold a long, thin piece parallel to the blade. With this, you’ll get smooth cuts. You should be able to get the 1/4” wide by 2&1/4 tall cuts on the table saw (maybe with 2 passes). You’ll lose a little more with the table saw kerf, but if your planer splinters these boards, they’ll be lost with that method.
View JayT's profile
JayT
5524 posts in 2119 days
#4 posted 09-12-2013 08:33 PM
Hand plane and a thicknessing jig would get you there quickly and safely.
View Dallas's profile
Dallas
3599 posts in 2395 days
#5 posted 09-12-2013 08:34 PM
2 1/4” wide? Build a thin strip jig and cut them on your table saw with a glue line rip blade.
Sand to a perfect finish, or use a card scraper.
View rrww's profile
rrww
263 posts in 2021 days
#6 posted 09-12-2013 09:07 PM
Drum sander would make short work of these.
View theoldfart's profile
theoldfart
9419 posts in 2359 days
#7 posted 09-12-2013 09:29 PM
Another hand tool option:
No limit on width with this setup
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
MrRon
#8 posted 09-12-2013 09:34 PM
I just tried finishing them with the surface planer and no problem. I was able to get them down to a uniform thickness. These are for sides for boxes. I have to make about 60 boxes and two 15” long strips will make one box. There’s a lot of cutting to do, so I’m looking for the best way so as to minimize waste. BTW, i’m using 2×4 material cut to 15” long lengths; running the boards through on the table saw to remove the rounded corners; then resawing as many 2-1/4”x1/4” pieces as I can get. With the bandsaw, I can get 4 strips, but If I use the table saw to resaw, I will lose one strip.
theoldfart
#9 posted 09-12-2013 09:36 PM
Hand plane may take a while :)
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 1980 days
#10 posted 09-12-2013 09:41 PM
Glad you made it through. Just be aware. I agree with others who have mentioned, that as soon you get that thin they can rip apart in the planer, especially at the exit. It has happened to me personally several times. I don’t know why I keep going back and trying, but oh well… Probably cause it is a PITA to get it clean another way.
-- Who is John Galt?
View tefinn's profile
tefinn
1222 posts in 2345 days
#11 posted 09-12-2013 09:53 PM
Most planers will plane down to 1/4” with no problem. I plane to 1/8” regularly using a carrier board or a piece of 3/4” melamine with cleats to hold it within the planer. Using the latter method I’ve planed to 1/16” on occasion. This is a common way to thickness thin material in a planer.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
View badcrayon's profile
badcrayon
37 posts in 1728 days
#12 posted 09-12-2013 10:14 PM
I can use my planer to get down to 1/16th an inch with an MDF sled and a little hot glue at te edges.
-- Bad Crayon Studio
joeyinsouthaustin
#13 posted 09-12-2013 10:29 PM
Just to throw it out there. I have used these methods as well. It does work, and the wood doesn’t fail every time…. but I have personally experienced failures using each method. Only once, without any sled, did it cause any lasting damage to my planer. I lost an impeller blade on a dwalt 735 planing oak to 1/4”. It usually has happened on exit, but on occasion in the middle. Now I am not trying to say this practice is dangerous, or should never be attempted. I am just sharing my experience, and echoing the experiences of other. I did have to fix a planer, and have bunged up a couple of knives…. That said, I still try it every now and then, so that says that.
View bigblockyeti's profile
bigblockyeti
4993 posts in 1628 days
#14 posted 09-12-2013 10:40 PM
The pine worries me a little, I have experience too thin (& strong) wood being shattered by planer blades that were in good shape. In addition to using a sled of some kind, it would also be a good idea to make sure all the boards are butted together tightly to reduce the chance of the blades grabbing the wood and cutting down on snipe at the same time.
MrRon
#15 posted 09-12-2013 10:54 PM
I don’t like the idea of planing a piece that is rough on both sides. Maybe it would be better if I took one slice, set it aside and run the rough stock through the planer to get a smooth surface; then take another slice with the bandsaw and so on. Then I will end up with a lot of smooth, one side slices that I can run through the planer at my final 1/4” setting.
