strip/refinish rosewood knobs and totes
Forum topic by Tugboater78 posted 09-12-2013 03:12 AM 2272 views 0 times favorited 9 replies Add to Favorites Watch
View Tugboater78's profile
Tugboater78
2746 posts in 2244 days
09-12-2013 03:12 AM
Topic tags/keywords: question refurbishing finishing
How is best to go through this, have 2 sets that have some unsightly paint splotches. I want to clean them up and make them pretty again. Final finish would be? BLO/wax? Or should I poly/varnish/ laquer?
-- "....put that handsaw to work and make it earn its keep. - summerfi" <==< JuStiN >==>=->
9 replies so far
View Loco's profile
Loco
210 posts in 1801 days
#1 posted 09-12-2013 02:26 PM
What kind of rosewood ?
-- What day is it ? No matter. Ummmm What month is it ? No moron. I paid for a 2 x 6. That means Two inches by six inches. I want the rest of my wood.
Tugboater78
#2 posted 09-12-2013 11:06 PM
Whatever kind Stanley used on their prewar planes
View shampeon's profile
shampeon
1775 posts in 2235 days
#3 posted 09-12-2013 11:58 PM
Rosewood is oily enough to not need a finish. You can sand to a high grit and wax. Adding BLO or Danish oil or whatever will darken the wood, which may obscure the grain. I’ve done it, and on some totes/knobs it looks good, but others the distinctive grain would be practically invisible.
I’ve also used shellac on some knobs and totes. It enhances the grain nicely, but I find I don’t really like the feel of a hard finish all that much.
View HorizontalMike's profile
HorizontalMike
7768 posts in 2966 days
#4 posted 09-13-2013 12:09 AM
If you BLO Rosewood you will disperse the oils and muddle the details. Sand the Rosewood, and then finish with a clear lacquer like “Deft”. This will help keep the details without the above. IMO…
View BigRedKnothead's profile
BigRedKnothead
8519 posts in 2034 days
#5 posted 09-13-2013 12:19 AM
A drill press helps a lot sanding the knobs. ROS or any way you can with the totes. Like HM, I prefer aerosol shellac or lacquer. BLO darkens the rosewood too much for me.
My latest fav has been watco satin lacquer in an aerosol can. Then buffed out with paste wax and steel wool.
-- "At the end of the day, try and make it beautiful....because the world is full of ugly." Konrad Sauer
View ShaneA's profile
ShaneA
6966 posts in 2650 days
#6 posted 09-13-2013 12:31 AM
I like to use a drill on the knobs. They go quickly. Just hand sand the totes. Sanding the rosewood versions is a walk in the park vs the beech ones. Then I just use wax.
View Loco's profile
Loco
#7 posted 09-13-2013 12:56 AM
Probably Hymenaea courbaril. The cronies of united Fruit raped mountains of it back then. Take it to 400 and get a hardwood floor finish or Brownells Tru-oil..
View Don W's profile
Don W
18788 posts in 2619 days
#8 posted 09-13-2013 01:02 AM
On rosewood I usually just wax them. But I use spray shellac from time to time as well.
I sand the tote to 800. The knob I put in the drill press and also gets sanded to 800.
if the tote is real bad I sometime.scrape it with a card scraper and knife blade to start.
Tugboater78
#9 posted 09-13-2013 04:02 AM
Thanks everyone, I took one tote down with a razor blade and some sandpaper. The grain was awsome so I don’t want to obscure it, I will throw some wax on it and call it good.
My Wards Master #6 has stained hardwood with some hard slick finish that I don’t care for, while the Walnut on one of my #5s I finished with BLO/wax is right on spot. Skip the BLO and just wax
I’ll chuck the knobs up in the press and sand em down and see what I get. Take down the other tote like I did the other one. Hopefully will get these done and finish the other work I have on the planes they belong to and see what I have.
