Question for router guys.
« back to Hand Tools forum
Forum topic by RussellAP posted 09-11-2013 07:58 PM 1584 views 0 times favorited 26 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3104 posts in 2491 days
09-11-2013 07:58 PM
Been using the router a bit more than usual due to some projects. I know most of you use a roundover bit on a hand held router, but what about mounting it in the table router. I have a small 1/3 HP router I could use I guess, but its just as easy to stick the bit in the table router.
Now my question is, seeing there is a bearing on the roundover bit, can I just use that without the fence at all? For small boards it’s easier that way for me. I tried it on the last two boards and it worked well, but I don’t want to find out the hard way that it’s not safe.
26 replies so far
View Don W's profile
Don W
19018 posts in 2772 days
#1 posted 09-11-2013 08:01 PM
That’s what I do. You just need to be careful on the start.
View chrisstef's profile (online now)
chrisstef
17767 posts in 3211 days
#2 posted 09-11-2013 08:02 PM
I just did a ton of roundovers on the router table and I just popped the bearing off the bit and used the fence. I don’t see why you couldn’t do it without a fence and leaving the bearing on though.
View ShaneA's profile
ShaneA
7053 posts in 2803 days
#3 posted 09-11-2013 08:05 PM
Just set the fence parallel/flush with the bearing. Use a ruler or straight edge and you should be good to go.
5177 posts in 2698 days
#4 posted 09-11-2013 08:13 PM
Usually, if you use a bearing bit without a fence, you need a “starter pin”. As the name implies, it lets you get started (without kickback) and then you can move away from the pin.
16281 posts in 4423 days
#5 posted 09-11-2013 08:14 PM
The safest and easiest way is just like Shane said. Working without the fence is easy enough for most of the length of the board, but starting and finishing the cut can be tricky because the bit will have a tendency to want to keep cutting around the perimeter of the board.
View tefinn's profile
tefinn
1222 posts in 2642 days
#6 posted 09-11-2013 08:19 PM
If you use the table, set it up like Shane says. That’s the way I do it. I also use my trim router for doing it by hand if the table has a setup in it already.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
View mds2's profile
mds2
310 posts in 2149 days
#7 posted 09-11-2013 08:28 PM
Another vote for Shane’s idea. I do the same.
View kdc68's profile
kdc68
2691 posts in 2482 days
#8 posted 09-11-2013 08:33 PM
+1 ShaneA and Fred Hargis.....Shane’s method works great for straight work pieces …Fred’s method works great for curved or odd shaped work pieces that a fence would prohibit you from forming the roundover
-- Measure "at least" twice and cut once
View Earlextech's profile
Earlextech
1162 posts in 2895 days
#9 posted 09-11-2013 08:38 PM
I’m with Shane.
View Bob817's profile
Bob817
673 posts in 2587 days
#10 posted 09-11-2013 08:54 PM
I too do the same as Shane.
-- ~ Bob ~ Newton, N.H.
RussellAP
#11 posted 09-11-2013 09:11 PM
ShaneA, It’s the rounded corners that I was wondering about. I actually did flush the fence with the bearing, but on a round corner like in the pic you have to free hand it.
I’m wondering if I could use a one piece fence instead of the two piece I have now, just let the bit eat through it like a TS zero clearance insert.
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2277 days
#12 posted 09-11-2013 09:18 PM
Here is a combo method. Especially good for your boards. We set up our large shaper this way for crowned raised panels. Do a straight fence to the right of the bit for straight edges, and then no fence left of the bit for “following” the curved edge around. You need flat table around the left side of the bit, some supports or dust hoods can get in the way. The fence works as the starter pin. Reverse the router if you can, or the fence set up if you are doing climbing cut. (Depending on the size of the R.O. and comfort level) With the right set up you can also get much better dust collection this way. Look at the dust hoods at the weaver shaper site and it will give you ideas. Rather than behind the bit only, they extend around to catch more where the chips are initially coming off.
-- Who is John Galt?
joeyinsouthaustin
#13 posted 09-11-2013 09:21 PM
Reading that I wanted to add a description of the “action” Start with a straight against the fence, and start it forward into the bit, once it is near half way, and set on the bearing, tilt it away from the fence and follow the curve around the edge and a little into the next flat. Then start the next side flat on the fence and proceed as before until all four sides are done.
kdc68
#14 posted 09-11-2013 09:36 PM
”It’s the rounded corners that I was wondering about. I actually did flush the fence with the bearing, but on a round corner like in the pic you have to free hand it.”
+1 joeyinsouthaustin....that would work….great suggestion…
or back to Fred’s suggestion to use a starting pin from post #4. Insert a starting pin in your router table plate and away you go. Wouldn’t need a fence at all, just the pin to start the cut safely. Once engaged into the cut, pull away from the pin and route all four sides….
RussellAP
#15 posted 09-11-2013 09:37 PM
I’ve never used or seen this pin you are all talking about. Is there a video or something?
