Sanded my cradle slats too narrow.
Forum topic by wolfhound1 posted 09-11-2013 07:27 AM 1012 views 0 times favorited 3 replies Add to Favorites Watch
View wolfhound1's profile
wolfhound1
4 posts in 1883 days
09-11-2013 07:27 AM
Topic tags/keywords: question
I’ve been trying to follow a pendulum cradle plan made from Ash and I ended up with my slats too narrow for the rails. Just enough to be loose. The plan calls for spacers in between each slat, which fit well. My question: Is there a decent way to secure the slats while maintaining a tight finished look? OR should I just make new slats?
3 replies so far
View Gary's profile
Gary
9333 posts in 3462 days
#1 posted 09-11-2013 12:13 PM
Picture?
View eruby's profile
eruby
79 posts in 2803 days
#2 posted 09-11-2013 12:21 PM
off the top of my head you could try:
1. epoxy or another gap filling adhesive
2. wrap the top and bottom of the slats w/ veneer and re-fit
2a. try putting the veneer in the grooves (or fill the grooves completely) and re-mill the slots to match the slats. (I had to do this for a bookshelf that I made) Sometimes you can put wood back.
3. leave them alone and let them wiggle as long as the slats are not a structural component, stay in place and wont fall out when the little one kicks them.
good luck
-- Eric - Baltimore MD
wolfhound1
#3 posted 09-15-2013 06:49 AM
I had enough ash left over to make 2 new bottom rails. If I tack the slats in the top rail with hot glue I think I can hide any gaps visible from underneath. Besides, I don’t think the kid will complain until I’ve taught him enough to critique fine woodworking. Thanks all for the advice.
