How to Get a Smooth Finish With Paint On Bare Wood?
Forum topic by Mean_Dean posted 09-10-2013 06:23 PM 37894 views 1 time favorited 19 replies Add to Favorites Watch
View Mean_Dean's profile
Mean_Dean
6477 posts in 3143 days
09-10-2013 06:23 PM
Hey Guys,
I just finished a set of cabinet doors, out of poplar, and finished them with a good-quality paint, but the texture of the paint is rough to the touch, not smooth.
These are the steps I followed:
#1) Sanded the doors to 150 grit
#2) Brushed on 1 coat of Kilz water-based white primer, and allowed it to dry overnight
#3) As the grain was raised, I sanded the primer with 150 grit to smooth it.
#4) With the primer coat now smooth, I brushed on 1 coat of the water-based, latex paint, and allowed it to dry overnight
#5) The texture was a bit rough, as I brushed on the 2nd (and last) coat, and let it dry overnight
The texture is slightly smoother, but still feels a little rough to the touch. Does anyone have any suggestions to get a smooth finish? Am I doing something wrong, or skipping a step?
Any suggestions are greatly appreciated!
-- Dean -- "Don't give up the ship -- fight her 'till she sinks!" Capt James Lawrence USN
19 replies so far
View JayT's profile (online now)
JayT
5624 posts in 2206 days
#1 posted 09-10-2013 06:27 PM
The best way I know to get a really smooth finish is to spray.
If you can’t spary, make sure to have a really good quality brush and add some Floetrol to the paint. That will help it self level much better.
View DrDirt's profile
DrDirt
4424 posts in 3738 days
#2 posted 09-10-2013 06:31 PM
http://www.finewoodworking.com/how-to/article/better-painted-furniture.aspx
http://www.finewoodworking.com/how-to/article/three-steps-to-a-flawless-painted-finish.aspx
FWW did a few articles –
One used a tinted lacquer brushed on
The other (better painted furniture) used automotive products, and talks extensively about using auto primer, which acts as a grain filler also to get glass smooth surface to paint.
Key is getting the surface level and sealed – so the primer is the most important.
Good luck
View Kaleb the Swede's profile
Kaleb the Swede
1832 posts in 1965 days
#3 posted 09-10-2013 06:33 PM
Did you tip it after you brushed? I spread an even coat and then right away take a clean brush and run the tips over the surface to give it a very nice finish. That’s how I was taught when painting my dad’s 145 commercial fishing vessel. I was always responsible for hanging over the side and doing the lettering. Of course that is a steel boat not a wood one. Tipping though is key, I did that with the front door of my house.
-- Just trying to build something beautiful
4984 posts in 2489 days
#4 posted 09-10-2013 07:14 PM
I think it may have been the paint. If that was just a latex paint, as in paint for walls, then you may have done much better with an acrylic latex.
View tefinn's profile
tefinn
1222 posts in 2432 days
#5 posted 09-10-2013 07:23 PM
Those FWW articles are only available to paid subscribers!
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
View Clint Searl's profile
Clint Searl
1533 posts in 2357 days
#6 posted 09-10-2013 07:31 PM
What I do:
1. Sand to 220, and remove all dust
2. Brush or roll a coat of flat latex/acrylic premium wall paint. I prefer Behr. Skip the shellac.
3. Smooth it back with 220 drywall sanding screen.
4. Repeat steps 2 & 3
5. Brush or roll the final coat in the sheen of choice.
I usually stick with flat and top with either waterborne poly if brushing or CAB acrylic solvent lacquer if spraying
404 - Not Found
2544 posts in 2965 days
#7 posted 09-10-2013 07:31 PM
Foam rollers will give you a good finish if you can’t spray. Build a heavy primer base and sand it back glass smooth, then top coat.
View Earlextech's profile
Earlextech
1161 posts in 2686 days
#8 posted 09-10-2013 07:44 PM
Latex is never a proper final finish on any cabinetry or furniture projects. You should be using a tinted lacquer/poly/shellac for a furniture quality finish.
If you’re going to stick with latex, add Floetrol and use a foam roller or a $30 brush.
View bondogaposis's profile
bondogaposis
4723 posts in 2347 days
#9 posted 09-10-2013 07:50 PM
Sand the primer to 320 before apply paint. Sand each coat of paint to 400 except the final coat. Rub the final coat w/ a brown paper bag if it is rough.
-- Bondo Gaposis
Clint Searl
#10 posted 09-10-2013 08:45 PM
Why isn’t latex/acrylic ever a proper finish? Inquiring minds want to know.
View Charlie's profile
Charlie
1100 posts in 2282 days
#11 posted 09-10-2013 08:54 PM
We topped our painted cabinets with some water-based, satin poly. So far, a bit over a year in service and they look great. Have to let the acrylic dry well before putting poly on.
Earlextech
#12 posted 09-10-2013 08:56 PM
Clint, Really or are you just playing?
I know you agree because your post says you top coat with poly. For others that don’t know, latex is house paint. Go ahead and paint a table top with latex, let it cure as long as you want, then put all your favorite things on it. Framed pictures, humidor, books. Let them sit there for a couple of days. Now try to remove them without pulling the paint off.
Also, latex was not designed to be sprayed. It just doesn’t lay down a nice smooth finish like a lacquer or a poly.It has to be modified to spray and that can ruin the properties of the paint.
Latex is rubber, if you want a rubber finish on your furniture, great, but I don’t and my customers don’t.
Clint Searl
#13 posted 09-11-2013 12:35 AM
Sam, I may have misunderstood your earlier comment. I’m a big fan of interior acrylic wall and trim paint for anything colored. It (I prefer flat) goes on smooth and builds fast. I always top it with a waterborne poly or solvent lacquer, though I think that in semi -gloss or gloss, premium formulations dry hard and fast enough NOT to exhibit the stickiness of the old latexes. I wouldn’t hesitate to use it on cabinets.
View jap's profile
jap
1251 posts in 2049 days
#14 posted 09-11-2013 01:17 AM
This is an interesting read on painting a mirror finish http://forums.shoryuken.com/discussion/67501/how-to-paint-mdf-to-a-mirror-finish-worklog
-- Joel
View BentheViking's profile
BentheViking
1782 posts in 2559 days
#15 posted 09-11-2013 02:35 AM
I just redid all my cabinet doors by spraying enamel and they came out great. Assuming you can’t spray then try at least brushing/rolling it on. Its pretty thin so even thick coats leveled out nicely. I used SW Proclassic Latex enamel. And no stickiness after it dries.
-- It's made of wood. Real sturdy.--Chubbs Peterson
