curly maple bar top
Forum topic by jcmeyer posted 09-10-2013 07:07 AM 1455 views 0 times favorited 6 replies Add to Favorites Watch
View jcmeyer's profile
jcmeyer
3 posts in 1717 days
09-10-2013 07:07 AM
I’m in the process of creating a bar using curly maple on top. How do you reccomend that I finish the bar top? In the past, I have used aniline dye and shellac for curly maple furniture. However, this time I want it to be able to withstand having cold bottles of beer, etc. on it.
thanks!
View NiteWalker's profile
NiteWalker
2737 posts in 2573 days
#1 posted 09-10-2013 09:35 AM
Two finishes come to mind.
Crystalac makes a bar top and floor finish called polyoxide that seems pretty good. I’ve used it, but not on a bartop and it seems durable enough.
Epoxy would be the other bartop finish. Before either finish I’d use something to give the curly grain a bit of pop. For my waterborne clear coats I first coat with a coat of sealcoat tinted with a few drops of dark vintage maple transtint. I’m not sure if that will work under epoxy.
View hydro's profile
hydro
208 posts in 1748 days
#2 posted 09-10-2013 12:40 PM
I’ve used regular polyurethane for table and bar tops with great success. My kitchen table was refinished 25 years ago with three coats of poly and has withstood constant water, impact, and other abuse, and still looks great. My bar top was done with three coats of gloss Minwax solvent base poly. The gloss is important because it does not contain flatteners that cloud the finish. The last coat to go on is semi gloss for the right sheen. Again here, it is holding up great.
The nice thing about this product is that it is easy to locate, sprays well, and does not cost a fortune!
-- Minnesota Woodworkers Guild, Past President, Lifetime member.
View Clint Searl's profile
Clint Searl
1533 posts in 2358 days
#3 posted 09-10-2013 01:38 PM
Waterborne poly floor finish.
jcmeyer
#4 posted 09-10-2013 01:57 PM
Thanks for the responses so far. Does anyone know how the poly or epoxy top coats would affect the aniline dye?
View Charlie's profile
Charlie
1100 posts in 2283 days
#5 posted 09-10-2013 02:07 PM
Waterlox. :)
I think it’s just a phenolic resin varnish but it’s tough stuff. Extremely easy to repair/refinish. I wiped my entire, 8 foot long, island top down with mineral spirits because I thought I’d be refinishing the entire thing when I had to recut a corner after the top had been in use for a year. The mineral spirits just cleaned it really well. Didn’t touch the finish. I recut and refinished the bare wood and then blended the new finish into the old finish by padding on a couple of coats and feathering them into the old finish. I can’t find a transition between old and new and I’m the one that did it. :)
Poly – I like it for times when it’s the best, but I have to admit I’m not in the “poly everything” camp. If you do go with a polyurethane, I’d definitely be looking for a floor finish type, and solvent based. I haven’t personally had to repair it, but I think you’d have to refinish the entire piece as opposed to doing any spot repairs. Others might dispute that and I will absolutely yield to someone more experienced with poly on that one.
Hard to beat the scratch resistance/chemical resistance of a good epoxy finish, but not easy to repair/refinish. And a bit harder to apply correctly.
NiteWalker
#6 posted 09-10-2013 02:34 PM
I’ve used waterborne poly over dyes with no problems. Spray for best results.
